Congrats and good luck tonight on this. I may be asleep before you decide to hang it up for the night, your new toy and all. You got it made in the shade. (Thx for your feedback on the Dell ... I only posted that to make you feel guilty about the 76 you got ...)
System76 Bonobo Extreme
Originally posted by Qqmike View Post(Thx for your feedback on the Dell ... I only posted that to make you feel guilty about the 76 you got ...)
one mite ask ,,,,,,,"well Vin" why do you need a 76 when you have a relatively nice Dell ?
so one mite answer ,,,,,,,, well wants may be needs !!
.................................................. partitioning done .................................................. ..
Code:vinny@vinny-Bonobo-Extreme:~$ sudo parted -l [sudo] password for vinny: Model: ATA HGST HTS725050A7 (scsi) Disk /dev/sda: 500GB Sector size (logical/physical): 512B/4096B Partition Table: msdos Number Start End Size Type File system Flags 1 8225kB 323GB 323GB primary ext4 boot 3 323GB 379GB 56.3GB primary ext4 4 379GB 496GB 117GB extended 5 379GB 436GB 57.0GB logical ext4 6 436GB 496GB 59.8GB logical ext4 2 496GB 500GB 4295MB primary linux-swap(v1) Model: ATA HGST HTS721010A9 (scsi) Disk /dev/sdb: 1000GB Sector size (logical/physical): 512B/4096B Partition Table: gpt Number Start End Size File system Name Flags 1 1049kB 1000GB 1000GB ext4 primary
3 is the new home of Kubuntu-14.04
5 & 6 is yet to be decided
Humm just noticed the gpt partition table on the TB drive,,,,,,,never had one of these before ,,,,,,,,,,,more reading to do
Not that you asked, not that you wouldn't stumble-upon-them,
Start
http://en.wikipedia.org/wiki/GUID_Partition_Table
At Arch
https://wiki.archlinux.org/index.php/GPT
Large drives, GPT, Linux (IBM stuff is always good):
http://www.ibm.com/developerworks/linux/library/l-gpt/
Linux on 4KB-sector disks (IBM again):
http://www.ibm.com/developerworks/li...-sector-disks/
Rod Smith's GPT fdisk tutorial (it includes additional basic/intro sections on his website):
http://www.rodsbooks.com/gdisk/
Make you an expert in case I need help someday. I read this stuff and quickly forget it. Use it or lose it.
... and GParted Live CD supports GPT, also. You can create a GPT disk (e.g., try it on a flash drive).
GParted enables you to easily manage your disk partitions:
- Create partition tables, (e.g., msdos or gpt)
http://gparted.org/features.phpAn intellectual says a simple thing in a hard way. An artist says a hard thing in a simple way. Charles Bukowski
Hey Vinny, fire up Stellairum and tell me what FPS you get. I get 30, sometimes more. I'm running the i915 driver (nouveau) and it works pretty well on most HiRes graphics. Universe Sandbox2 gives me 60 fps max and drops to 30 or so when I have lots of objects flying around. My GTX 650M is not selectable in BIOS so I would have to use Bumblebee/Optimus to run graphical apps. It turned out that Nouveau worked just as fast as Optimus."A nation that is afraid to let its people judge the truth and falsehood in an open market is a nation that is afraid of its people.”
@GG stellarium gives 20FPS at idle(siting still) and up to 60 zooming in and out......... this GTX 860M has 1152 cuda cores
@Qqmike thanks for the links ,,,,,,, will read up on this ,,,,,,after installing Kubuntu this evening
Originally posted by vinnywright View Post@GG stellarium gives 20FPS at idle(siting still) and up to 60 zooming in and out......... this GTX 860M has 1152 cuda cores
..."A nation that is afraid to let its people judge the truth and falsehood in an open market is a nation that is afraid of its people.”
Originally posted by GreyGeek View Post60 FPS is the vertical sync rate, probably the max. Is your display set on "auto" or fixed at "60 Hz"?
Originally posted by MoonRise View PostNice screen..... congrats!
OK so kubuntu is in now , Weeee
installed to /sda3 with a USB-3 Kubuntu-14.04-Liveusb in a USB-3 port(they all are) no downloading of extra packages or updates during the install .
Grub installed to /sda3 so as not to mess with Ubuntu's grub.
It was the quickest install I have ever done ,,,,,,,,,realy not 3min after I finished the , timezone , keyboard layout , user info, part of the install it was done .
Restarted opend a terminal andCode:sudo apt-get update && sudo apt-get dist-upgrade
All is well ,,,,,start playing around ,,,,,,,,,,,,,,,,,,,,,,,,,,,
Noview or whatever the default graphics driver for Nvidia is was not cutting it .
their was no GL and my favorite effect 3D cube was not working .
The "driver manager" in system settings was not offering me anything (maby the card is to new)
So ,,,,,, added the system76 PPA and installedCode:vinny@vinny-Bonobo-Extreme:~$ apt show system76-driver-nvidia Package: system76-driver-nvidia Source: system76-driver Priority: extra Section: utils Installed-Size: 36.9 kB Maintainer: System76, Inc. <dev@system76.com> Version: 14.04.10 Depends: ubuntu-drivers-common, nvidia-331-updates Conflicts: nvidia-current-updates Download-Size: 4,372 B APT-Manual-Installed: yes APT-Sources: http://ppa.launchpad.net/system76-dev/stable/ubuntu/ trusty/main amd64 Packages Description: Latest nvidia driver for System76 computers This dummy package depends on the latest driver tested with and recommended for System76 products with an nvidia GPU. . When this package is installed, you will automatically be upgraded to newer nvidia driver versions after System76 has thouroughly tested them. . This driver will generally depend on a newer nvidia driver than the official nvidia-current-updates Ubuntu package. . If you don't want to be automatically upgraded to newer nvidia drivers, simply remove this package.
now off to build my system up to how I like it ..........................
☢VINNY☢i7 4core HT 8MB L3 2.9GHz
getting their .................................................. ............................
and some windows open .................................................. ....................
still need to do some more aesthetics ......hear and their and a bit of system tweaking like adding the TBdrive to fstab and moving all the home DIR's their and then linking them back but ,,,,,,,,,,,,so far so good
Pan-Galactic QuordlepleenSo Long, and Thanks for All the Fish
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
Noticed this on the Ubuntu side...
Purge the package unity-scope-home to get rid of the Canonical-Amazon spyware.
Originally posted by SteveRiley View PostNoticed this on the Ubuntu side...
Purge the package unity-scope-home to get rid of the Canonical-Amazon spyware.thanks .
dont know when I'll make it back to that partition ,,,, but when I do it will be the first thig I do
- Jul 2011
- 9524
- Seattle, WA, USA
- Send PM
