OK so a few day's from getting this thing ,,,,I think ,, but would like some input as to where to maby get similar equipment for less ,,,or if it's a good deal for the $
hear is the config as of now
well what do you all think ? worth $2375.54 with shipping
Base System $1,579.00
Ubuntu 14.04.1 LTS 64 bit
17.3" 1080p Full High Definition Matte Display ( 1920 x 1080 )
nVidia GeForce GTX 860M with 4 GB GDDR5 Memory and 1152 CUDA Cores
4th Generation Intel® Core™ i7-4910MQ Processor ( 2.9 GHz 8MB L3 Cache - 4 Cores plus Hyperthreading ) $389.00
16 GB Dual Channel DDR3 SDRAM at 1600MHz - 2 X 8 GB $115.00
500 GB 7200 RPM SATA II
1 TB 7200 RPM SATA II ($119) Save $20! $99.00
No mSATA drive
No mSATA drive
United States Keyboard Layout
8X DVD±R/RW/4X +DL Super-Multi Drive
Intel® Dual Band Wireless-AC 3160 AC Wireless LAN up to 433 Mbps + Bluetooth
No Bag
Extra 89.20 WH 8 Cell Smart Li-ION Battery $135.00
1 Yr. Ltd. Warranty and 1 Yr. Technical Support
No mSATA drive
No mSATA drive
No Bag
