DirectDraw Surface Viewer for Linux??
    I have some "DirectDraw Surface" images I would like to keep in the original format but I would like to view them. As you may already know DDS is a MS format and I did the usual search on the webpages and came out with nothing for Linux. IF I must use a windows program through WINE that is ok but I would hope by now someone has an addon or something for this format.
    This? https://launchpad.net/ubuntu/+source/gimp-dds
      Preview
      The KDE DDS support was added to the 'old' KDE 3, https://bugs.kde.org/show_bug.cgi?id=78117 ,and it seems to work with the KDE 4.11:
      The KDE file managers have the preview option. With the Dolphin > Settings > Configure Dolphin > General > Previews > Enable the 'Images' preview.
      and preview... (at here with the 'Show tooltips')
      The KDE document viewer - Okular - can show the DDS files.
      At here the Okular is the default application for the DDS files. KDE System Settings > File Associations > dds ...
      Other - ImageMagick
      The ImageMagick - Display shows the DDS files and it can be added to the 'File Associations'
      More of the preview:
      - http://askubuntu.com/questions/86338...iew-in-dolphin
      - http://askubuntu.com/questions/12505...k-look-for-kde
        Imageviewers
        The standard KDE imageviewer - The Gwenview shows the DDS files:
        Non standard option is the XnView (Win/Mac/Linux) : http://www.xnview.com/en/index.php
          Thanks, I now see the issue with the files I was given. None of them have the dds extentions so dolphin, gwen, etc.. doesn't "see" them.
          I thought it was a Linux vs Windows issue but it is not.
