Just bought a new battery for my laptop. The 'puter is 6 years old but still works fine and at this point I figured if I can get another couple of years out of it for a £25 investment for a 7800mAh battery then the missus might be happy to see me buy a humdinger next time
Anyway, this is my 3rd battery for this machine. I ran with the first one bust for 2 years but bought a new one 18 months ago at the same time as my daughter (we both have Dells). Hers is still going okay (about 1.5 hours) whereas mine got down to 10% capacity (warning lights after a few seconds). I have put that down to the fact that I have tended to leave mine switched on, connected to the mains, for extended periods whereas she tends to run it on battery rather more - a little ironic.
From previous searches of the net on how best to look after a laptop battery the advice varied greatly and was confusing. One school of thought was that it should be fully discharged from time to time, whereas another was that doing so would wreck it. Others say charge when it's at 40% and ensure it's at that level when you store it. Any thoughts on a sensible regime I can employ to make sure this one will last as long as possible?
Thanks
Thanks
