"Komplete" beta ready for testing
    Greetings Kubuntu Users:
    Komplete is an "Automatix-type" program for KDE/Kubuntu. It is designed with KDE in mind. Currently in beta stage we're looking for testers. If you have any comments, suggestions or bug reports, please post it here.
    GoogleNinja (the coder) says:
    "It has a few less features than Automatix currently. It's more a framework than anything else. If the current structure works then adding new and multiple modules will be a breeze."
    Link: http://dapperdrake.50webs.com/kompletebeta.tar.bz2 to download.
    Installation: Untar the file and run
         sudo ./komplete-script
    GoogleNinja offers a bit of clarification:
    1) This is 99% the same code that automatix uses to actually do stuff. So when you are installing opera through this, it is doing to your system exactly what automatix does. I totally ripped em off.
    2) The cool bits of Komplete is that its more of a framework than anything. To add another installation task, you will be able to just copy/paste a block of code at the top, make it executable, then throw it in a folder. It will then show up in the GUI, will interact with the progress bar, etc. To add a category, you just make a different folder. If you want to use it for something totally different, just trash everything in scripts/ and start from scratch. 90% of tutorials on forums have everything you need to automate the task already, I thought it would be nifty to have a GUI framework for it.
    3) This is just the "it runs" release. It does less then automatix, the only difference you will (or should anyways) see is graphical. The next step is Un-install support (i already know how im gonna do it), and getting away from gnome-centric stuff. I have wrapper methods around all gui-ish stuff, so theoretically i could put zenity back in as a command line option, so you could pass --qt or --gtk and get displays using the different toolkits. What I see for this though is something that will allow me to set up kde as easily and quickly as automatix allows you to set up gnome, while letting me NOT have to install half of gnome to do it. My goal is to run kubuntu without even having GTK on my machine.
    anyways, comments/flames are always appreciated, feel free to email me at hyuga.citan@gmail.com.
    Matt
    Re: "Komplete" beta ready for testing
    Cool! I like how it's made! makes it easy for anyone to make a script
    Suggestion: script for fglrx. I know how to do it... but I have no idea where the supported fglrx cards are.
    <br /><br />*temp. hiatus from forums due to comp + net broken* :&#039;(
      Re: &quot;Komplete&quot; beta ready for testing
      Hey, Nirvana. Great to hear from you. I'll let my friend GoogleNinja know about the desired additions. For the time being we're looking for any aspects that appear to be a bug. Of course additional components are welcome.
      We admit this application has less in it than Automatix does. Our goal is to test it as best we can and then begin to add more components. So if you haven't found anything that doesn't install or makes your PC hiccough, then we're doing fine!
      Keep the bug reports coming!!
        &quot;Komplete&quot; or the new &quot;Automatix&quot; for Kubuntu
        Komplete has some competition!
        There is a new version of Automatix for Kubuntu over at the Ubuntu forums (http://www.ubuntuforums.org/showthread.php?t=203294). We haven't tested it but we'd like comments from users which they prefer.
        If the new Automatix is considered better we'll abandon the Komplete project. If not, and we hear enough to that end, we'll maintain it.
        It's your choice folks!
          i fully agree to bobsongs.
          Automatix have much more features, lets ALL keep our eyes on AUTOMATIX
          and help them!
          i am not saying Komplete isn't good, but automatix is in a higher patamar.
          and we should help them instead of make a competitor.
          look at GNOME and KDE.
          if ALL people fix their eyes on KDE, KDE will have MUCH more apps and funcionalities.
          better for Linux users, better for us, better for ALL.
          bye
            Well. I don't see how you can agree with me since I didn't state any particular position there, Fidelix. Variety is the spice of life. Variety challenges others to rethink their software. Competition is healthy for this environment.
            Are you suggesting one kernel, one command prompt shell and one windowing system? If so, you're thinking of a certain product from Redmond, Washington.
              This does what exactly? I'm not familiar with this "Automatix" thing
              LINUX. IT&#39;S SO EASY, EVEN A PENGUIN CAN DO IT.
                A word of warning - STAY AWAY FROM AUTOMATIX -- IT WILL SCREW UP YOUR SYSTEM BY TRASHING YOUR /etc/apt/sources.lst FILE!! It may not happen immediately, but it will eventually. Search the Forum on Automatix and you'll find posts where members had it happen to them.
                Stick with Adept Manager (installed by default) or install Synaptic - another GUI package manager - that works nicely within Kubuntu, and doesn't mess with your /etc/apt/sources.lst file.
