advantage running dual core
    What would the advantage be to replace a 2GHz processor with a 2GHz dual core processor, running 32bit software?
    - kubuntu 11.10 | linux User #231826 | kubuntu user #23718<br />- x58/ich10r | i7-950 | 3@2GB 1600 3x channel | geforce gt240 1GB [19&quot; 16:10, 19&quot; 4:3] | 120GB ssd / 500GB / 1TB / dvd+-rw [sata ahci] | 600W wrapped in aluminum
    Re: advantage running dual core
    I am not sure. But doesn't dual core mean that it likes there are 2 processors in processing. So I thought it would effect if the software itself using multithread. Just guesting...
    P4 3.06 HT,RAM 512 MB, 80GB HD, Geforce 6200 LE, Kubuntu 8.04
      That's my assumtion. The software must be mutlithreaded. So, is the kernel able to thread on each processor and how much advantage would running 32bit on a dual core give. In other words, would it be worth the money to upgrade simply to a dual core processor. All other reasons put aside, ie 64bit OS or >4GB RAM
        If your Linux kernel is "smp" (which these *buntu kernels are) then the kernel will automatically schedule both CPU cores in an optimal manner. It's also possible to run two instances of single-threaded applications, and one instance will run on each CPU core.
        Gnome Wave Cleaner (gwc) is a package that I have used in that way, on my Core 2 Extreme -- it runs both cores up to 100% while it is running the process on an audio file.
          I installed kubuntu on my girlfriend's quad core and all I can say is 'WOW'
          Used k9copy on a dvd and all 4 cores being used, but it was still very responsive. Shrank it in about 10 minutes. Running an apt-get update/upgrade, processing time was minimal. Being used to my own somewhat pedestrian PC I suggested a coffee while it updated, but what would have taken mine several minutes was over in seconds. I want one.
            Check this out
            http://ubuntuforums.org/showpost.php...&postcount=696
            IOW, even starting two processes in the same shell, both CPUs were used.
            Check out my blog for useful scripts and tips... http://igurublog.wordpress.com
