• I always perform (and strongly recommend) the following 6 (7) steps directly after any Kubuntu (25.04) desktop installation - this usually takes under 5-10 minutes (including reboot):
To do so --> open the Konsole terminal emulator from your --> Application Launcher --> System.
Due to preventing typing errors, please copy and paste the following commands one by one into Konsole - e.g. with your mouse or with "[Ctrl] [c]" and "[Ctrl] [Shift] [v]" - and execute them with [Return]. Double-check that you did not miss a letter or two.
--> Everything in grey behind a single "⦁" is a whole command and has to be copied as a whole - even if it is longer than one line.
1. Please correct a possible installation bug for ext4 file systems in the /etc/fstab file first
( = replace the "discard" option with "defaults", because a systemd timer for fstrim is already running) !
To not do both is recommended by e.g. Red Hat and the ArchWiki (and openSUSE, Debian or Ubuntu's main distribution also do not do it) !
Furthermore Red Hat and SUSE (openSUSE) also recommend in general to use a timer/fstrim instead of the "discard" option (and Fedora, Debian or Ubuntu's main distribution also use fstrim.timer instead) - except for special cases.
If you are unlucky, using the "discard" option in /etc/fstab may decrease the SSD's lifetime and can lead to performance degradation. Also fstrim can behave unpredictably when the "discard" option is addionally set…
In case you don't know whether you chose the ext4 file system during installation the chance you did is quite high as it is the default for Kubuntu 25.04.
And if you didn't choose ext4 the following two commands won't do anything (except making a backup of your /etc/fstab file).
If the bug has been corrected in the meantime, neither the following sed command a. nor b. will do anything at all either.
So instead of the last command (a.) then you can
The change will be applied with the reboot after step 6. (7.)
2. Reduce swappiness for desktop installations like it is suggested for *Ubuntu and like e.g. TUXEDO OS also does it
( = the system will use the physical memory modules longer and use the swap file or partition later).
If you are curious you can check the setting with sudo sysctl vm.swappiness now and then again after step 6. (7.) and the reboot.
3. Reduce systemd timeouts for desktop installations like KDE suggests for Plasma in their Distributions/Packaging Recommendations
( = the system will not "hang" for 90 seconds and longer from time to time when logging out, rebooting or shutting down).
I am reasonably conservative here and use 15 seconds, because on older machines it has seldom taken 10-13 seconds before certain services were able to gracefully quit by themselves (for example: KDE neon uses 15 seconds, TUXEDO OS and Garuda KDE use 10 seconds).
4.a) Change GRUB to show the boot menu for 1 second in single-boot systems
( = only Kubuntu is installed - this makes the boot menu much easier to access whenever you might need it).
4.b) Change GRUB to show the boot menu with all installed systems for 5 seconds in multi-boot systems
( = Kubuntu and another Linux or/and Windows are installed - and be sure to absolutely disable Windows fast startup if you intend to access the "C:" drive from Linux).
5. Update your system and your programs for the first time
(this is generally one of the first things you should do after installing any operating system).
6. Install fundamental missing software like
7. If you have a CD, DVD or Blu-ray drive, install the following to be able to play back video CDs, DVDs or Blu-rays.
You can select with [Tab] and confirm with [Return] in the following dialogues, select "Ok" and "Yes" to install.
• Bonus - individual and potentially less important things to do:
a. It is possible to remove Snap from Kubuntu 25.04 and to use the "traditional" Firefox and Thunderbird additionally to or instead of the Snaps
b. Enable Flatpak
(e.g. to increase your pool of available programs).
For further information you can have a look at this link: How to enable Flatpak in Kubuntu 24.04 LTS.
c. Enable password feedback for the command line interface
( = so you can see something like ***** instead of nothing when typing in your password in Konsole - like you can see it in e.g. Linux Mint and Garuda KDE).
d. Disable fast user switching
(e.g. for security or performance reasons in multi-user setups).
- sudo cp /etc/fstab /etc/fstab.orig (this makes a backup of your /etc/fstab file first)
- a. sudo sed -i '/ext4/ s/discard/defaults/' /etc/fstab (this replaces the wrong options with the right ones)
- b. alternatively sudo sed -i '/ext4/ s/discard/defaults,noatime/' /etc/fstab (this replaces the wrong options with the right ones)
- echo -e "# Reduce swappiness for desktop installation (default = 60)\nvm.swappiness=10" | sudo tee /etc/sysctl.d/99-sysswappiness.conf (this writes the modified value to your system)
- sudo mkdir -p /etc/systemd/system.conf.d && echo -e "# Reduce timeout (default = 90s)\n\n[Manager]\nDefaultTimeoutStopSec=15s" | sudo tee /etc/systemd/system.conf.d/99-systemtimeout.conf (this writes the first modified value to your system)
- sudo mkdir -p /etc/systemd/user.conf.d && echo -e "# Reduce timeout (default = 90s)\n\n[Manager]\nDefaultTimeoutStopSec=15s" | sudo tee /etc/systemd/user.conf.d/99-usertimeout.conf (this writes the second modified value to your system)
- sudo cp /etc/default/grub /etc/default/grub.orig (this makes a backup of your /etc/default/grub file first)
- sudo sed -i 's/^GRUB_TIMEOUT_STYLE=hidden/GRUB_TIMEOUT_STYLE=menu/' /etc/default/grub (this writes the first modified value to your system)
- sudo sed -i 's/^GRUB_TIMEOUT=0/GRUB_TIMEOUT=1/' /etc/default/grub (this writes the second modified value to your system)
- sudo update-grub (this updates your GRUB boot loader with the new values)
- sudo sed -i 's/^GRUB_TIMEOUT=0/GRUB_TIMEOUT=5/' /etc/default/grub (this writes the second modified value to your system)
- sudo sed -i 's/^#GRUB_DISABLE_OS_PROBER=false/GRUB_DISABLE_OS_PROBER=false/' /etc/default/grub (this writes the third modified value to your system)
- sudo snap refresh && sudo systemctl daemon-reload (this updates the Snaps - not necessary if you chose the "Minimal Installation" option)
- sudo apt update && sudo apt full-upgrade (this updates all of your installation except for the Snaps)
- sudo apt autopurge && sudo apt autoclean (this removes possible remains of the installation process)
- multimedia codecs etc.
- Microsoft Web and replacement fonts
- sudo apt update && sudo apt install kubuntu-restricted-extras gstreamer1.0-vaapi libvdpau-va-gl1 rar fonts-crosextra-carlito fonts-crosextra-caladea (this installs all of the listed above)
- sudo apt update && sudo apt install libdvd-pkg (this installs the video play back for optical media)
- sudo dpkg-reconfigure libdvd-pkg (this activates the video play back for optical media)
- reboot and enjoy Kubuntu 25.04 !
- Script to get rid of Snap (like e.g. Linux Mint and TUXEDO OS do - can also block snapd in a "Minimal Installation")
- Script to install "traditional" Firefox (the way e.g. Debian suggests, installs as shown on Mozilla.org - good option for the "Minimal Installation")
- Script to install "traditional" Thunderbird (installs as shown on Mozilla.org - good option for the "Minimal Installation")
- Script to reinstall Snap for release-upgrade (the name comes from its original purpose).
b. Enable Flatpak
- sudo apt update && sudo apt install flatpak plasma-discover-backend-flatpak kde-config-flatpak
- flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
- echo -e "# Enable password feedback\nDefaults pwfeedback" | sudo tee /etc/sudoers.d/pwfeedback (this writes the modified value to your system)
- sudo chmod 0440 /etc/sudoers.d/pwfeedback (this applies the correct permissions to the written file)
- echo -e "\n[KDE Action Restrictions] [\$i]\naction/switch_user=false\naction/start_new_session=false" | sudo tee -a /usr/share/kubuntu-default-settings/kf5-settings/kdeglobals (this writes the modified values to your system)
