Kubuntu 24.10 Missing Iwconfig
    Hey! Ok i updated from 24.04 to 24.10. No major issues as such but i have one annoying little problem. When i try to run iwconfig i get this error:
    Command 'iwconfig' not found, did you mean:
    command 'iconfig' from deb ipmiutil (3.1.9-3build2)
    command 'ifconfig' from deb net-tools (2.10-1.1ubuntu1)
    Try: apt install <deb name>
    I have net-tools already installed and YES i tried removing it and reinstalling it but i keep getting the same error.
    anyone able to help me out?
    See if you are able to install wireless-tools This is the package that allows you to run iwconfig
      Thanks Snowhog!. I tried that ut it gives me this:
      Package wireless-tools is not available, but is referred to by another package.
      This may mean that the package is missing, has been obsoleted, or
      is only available from another source
      Error: Package 'wireless-tools' has no installation candidate
        Ok i installed wireless-tools through snap. I found the iwconfig tool. Thanks for your help (AGAIN) Snowhog!!
