Fail into start Wayland and X11 not show title bar after upgrading from 24.04 to 24.10
    Hello,
    I tried to upgrade from 24.04 to 24.10, but I could not login from sddm to Plasma Wayland (always at the screen of login).
    I could switch into Plasma X11 but there is no title bar and I could not move window, or switch between them.
    I try to start Plasma Wayland by switch to Ctrl-F3, run dbus-run-session /usr/bin/startplasma-wayland
    But I get an error of:
    symbol lookup error: /lib/x86_x64-linux-gnu/libkwin.so.6: undefined symbol: wl_display_set_default_max_buffer_size
    and
    fusermount3: failed to access mountpoint /run/user/1000/doc: Permission denied
    error: fuse init failed: Can't mount path /run/user/1000/doc
    qt.qpa.wayland: "wl-shell" is a deprecated shell extension, prefer using "xdg-shell" if supported by the compositor by setting the environment variable QT_WAYLAND_SHELL_EXTENSION
    qt.qpa.wayland: Loading shell integration failed.
    qt.qpa.wayland: Attempted to load the following shells QList("xdg-shell", "wl-shell", "ivi-shell", "qt-shell")
    Thank for any reply.
    Thuan
