I just completed the upgrade to 24.10. Two problems:
1. I previously had a keyboard shortcut of "Meta+Tab" set for "Walk Through Desktops", allowing me to quickly switch between Desktop 1 and Desktop 2. The shortcut stopped working after the upgrade, but worse, when I try to recreate it, the "Walk Through Desktops" function doesn't seem to work at all anymore, whether I set it to "Meta+Tab" or any key combination. The "Walk Through Desktop List" also doesn't seem to work. This is a pretty major problem for me as I used "Meta+Tab" to switch desktops almost as often as "Alt+Tab" for switching between applications.
2. The current VPN connection no longer shows when I hover over the Wi-Fi icon in the toolbar. The first line is the current Wi-Fi connection, and the line below now says "Middle click to turn on airplane mode". Is there a way to get this back?
