Install to drive with LVM not possible to remove LVM partitions
    [DESKTOP] Install to drive with LVM not possible to remove LVM partitions
    I was upgrading my Aunts 16.04 to 18 to 20 to 22 to 24 and I realized I should just do a clean install. I was dealing with a boot drive that was too small too .. anyway, I decided to copy her data to another drive and then do a fresh install.
    The fresh install could not occur because I could only select an LVM partition or manual setup. I did manual setup last time and caused problems, so I'm not doing that again.
    Anyway, the installer would not let me clear /dev/sda to be just one partition, it left the boot and let me do an LVM partition.
    I thought LVM was going to be amazing but it caused so many problems... I just went to commandline and fdisked the partitions away and rebooted and got the clean install I wanted, but this is an oversite/bug.
    They make it so hard to post bugs now.
    Thank you. Kubuntu is awesome and is the replacement for windows 10.
    If the drive has no data on it, wipe it clean and try again. The installer isn't intended to be a drive management tool. It's abilities to modify drive partitioning is limited.
    If it were me, I would boot to the LiveUSB and open konsole, the run wipefs -a /dev/sda
    BE SURE YOU USE THE CORRECT DEVICE NAME if you have more than one drive. The wipefs command is not reversible.
    Once the drive is un-partitioned, the installer should offer you the "Use entire disk" option, which what I assume you want.
