Description of the problem:
When selecting "Try Kubuntu" and then attempting to install Kubuntu from the "Install Kubuntu" icon on the desktop, the installer freezes at the "Install Bootloader" stage. It becomes completely unresponsive, leaving no option but to force a shutdown by long-pressing the power button.
Solution:
Choosing "Install Kubuntu" from the initial boot menu works without issues. If you want to try Kubuntu before installing, you can select "Install Kubuntu" first, then choose to cancel the installation. This automatically starts the "Try Kubuntu" session. Installing Kubuntu from this state works without any problems.
Solution:
