I tried installing Kubuntu 24.04.1 from the iso I downloaded from kubuntu.org. I put it in Ventoy and rebooted the machine. Ventoy came up and I chose Kubuntu 20.02.1. Grub came up and I chose the Try or install Kubuntu option and pressed enter. The next screen said invalid magic number, then something about loading or installing the kernel first. The procedure I just mentioned worked for Kubuntu 24.04. Why doesn't it work now? Is there any way to fix this? Thanks.
Tried booting 24.04.1 iso, got invalid magic number error
A bad download? I suggest checking the check-sum. One can do this with dolphin, if you can boot some kind of KDE; right click the iso, properties, checksums tab. Or, any Linux, on the CLI sha256sum *.iso. Maybe even Ventoy can do it these days.Regards, John Little
Originally posted by Delboy85358 View PostI tried installing Kubuntu 24.04.1 from the iso I downloaded from kubuntu.org. I put it in Ventoy and rebooted the machine. Ventoy came up and I chose Kubuntu 20.02.1. Grub came up and I chose the Try or install Kubuntu option and pressed enter. The next screen said invalid magic number, then something about loading or installing the kernel first. The procedure I just mentioned worked for Kubuntu 24.04. Why doesn't it work now? Is there any way to fix this? Thanks.
24.04.1 is just the 24.04 iso with current updates included in its OS image.
I still suspect a bum download or a bad bit on the USB, perhaps. I have used ventoy (the current 1.0.99) and 24.04.1 a couple of times in recent weeks.
