In my experience upgrading a Linux distro, no matter which one, always results in a very very slow system with long startup and loading times. That is perhaps the main reason I always go for a clean reinstall of Kubuntu.
Are there more people out there who have the same experiences as I have? In the meantime, is there a way to upgrade and fix this problem?
If clean reinstallation is still the best option, then it seems I have to copy my .config folder someplace else and place it back in place after installation in order to get my settings back. Does this option also set back the custom installations of software? In the past I was a bit reluctant to use this option since I simply could not believe this works so I set everything back manually.
Enlighten me please,
For now I still have more than 200 days before 22.04 is obsolete so there is no rush. I like it however that Kubuntu signals you long before that moment comes.
