Multi-Boot btrfs grub not updating
    I have my system set to multi boot different flavors with btrfs. It works pretty well, normally.
    I just installed Kubuntu 24.04 to @ and @home, leaving all my other distros intact. My primary booting OS is Kubuntu 22.04
    Ku24 did not show up on the boot menu. So I mounted the @ subvolume from inside Ku22 and dug around with Krusader to see what was going on.
    Kubuntu 24.04 is missing both:
    • boot/grub/grub.cfg file
    • boot/efi/ directory where the EFI boot.cfg resides on 22.04
    It DOES have /etc/default/grub
    I ran
    sudo grub-mkconfig
    and
    sudo update-grub
    but there was no change.
    How do I update grub to add Kubuntu 24.04 to grub?
    Grub has OS Prober disabled by default.
    See https://askubuntu.com/questions/1475...able-os-prober
