Hi all,
Does anyone have the nvidia drivers installed on kubuntu 24.04, or know which version of them works correctly?
I have tried two of the methods shown here https://www.cyberciti.biz/faq/ubuntu...ietary-driver/
Using the GUI method, it advises me to install the nvidia-driver-470 metapackage (tried) but it didn't work for me.
Neither did the second method from CLI installing the same version:
The installation runs and finishes normally, but once the system reboots, after the grub startup the screen goes black and that's it. I have tried with the two kernels that my system currently has and with both of them the same thing happens. The only option I have left is to enter a root console, uninstall nvidia completely and reboot again with the noveau driver.
In previous versions of Kubuntu I have always had the nvidia drivers installed, but since this version (24.04 LTS) I have not been able to get them to work.
Any suggestions on this matter will be welcome. Thanks in advance.
sudo lshw -C display
*-display
description: VGA compatible controller
product: GK208B [GeForce GT 710].
manufacturer: NVIDIA Corporation
physical id: 0
bus information: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=nouveau latency=0 resolution=1920,1080
resources: irq:31 memory:f6000000-f6ffffff memory:e8000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:c0000-dffff
sudo apt install nvidia-driver-470 nvidia-dkms-470
