SDDM Not writable
    [CONFIGURATION] SDDM Not writable
    Hello
    When starting my session before the step of entering my password, a window appears.
    Configuration file */var/lib/sddm/.config/sddm-greeterrc" not writable
    Please contact your system administrator
    How can I fix this problem?
    OS: Kubuntu 24.04.1
    Mounted on HP pavillon p6356fr
    Regards​
    Try checking the directory ownership; it might have been set to be owned by root as opposed the the user sddm.
    Try:
    sudo chown -R sddm:sddm /var/lib/sddm/.config
