Just upgrade from Jammy to Noble and no "upgrade issues" found. It's a VM running on Oracle cloud , ARM64. After upgrade, first access with Nomachine gave a blank screen and nothing else. I can ssh normally and can even run some GUI applications remotely, even systemsettings. But when I try to RDP (or nomachine) I got "Unable to connect to remote host: No route to host". If I telnet to the vm using port 22 I got answer. If I telnet with 3389 or 4000 I got Unable to connect. I upgrade via GUI Nomachine access, which was working fine with Jammy. I have a NFS on another machine at the same network which I can remote access fine (it's a RHEL). Any idea of what can be happening? Both Nomachine and Xrdp services are running fine on the VM. I can see them with systemctl. I reseted the vm many times and things remain the same. SSH ok, RDP/Nomachine not. Thanks is advance.
