A report on some problems I have had with the upgrade from 22.04 to 24:04
1) AFter upgrade the system would not run a GUI. I could get in via CTRL-SHIFT-F5 and the system had been upgraded.
It appears to have created an new partition
On some examination I think it has ignored that the BIOS and system are set for the old BIOS boot not UEFI
The disk reports errors although fsck reports no problems
2) I use thunderbird email.
I have been unstalling.updating it from a downloaded tar file, rather than from Kbuntu.
When I installed Kbuntu 24.04 ( after problems in 1) Thunderbird came as a snap.
BUT it would not access my email server as it reported certificate errors.
By bringing down a tar file and using that all worked perfectly.
So there appears to be a problem with snap and other installs.
Any comments happily received but possibly my experiance might help
