Dell 7490 and Kubuntu 24.04
    Okay, this was running 22.04 LTS. Today, I tried the upgrade and it failed. So, I am trying to install via USB.
    It seems to install but once the laptop is restarted, the system complains about no bootable device.
    This has been an unmitigated disaster. Good thing I decided to try this after a major meeting last week.
    I am asking what Bios setting I need BEFORE installation and after installation because this should not be so @#$% difficult.
    Very respectfully,
    James
    Okay,
    My pain is someone else gain. I got it to install AND reboot successfully.
ID:	682036Click image for larger version
ID:	682039Click image for larger version
ID:	682040Click image for larger version
    It was UEFI all the way.
      Ongoing with the other assets:
      I upgraded the Dell T7500 with Nvidia using the GUI upgrader.
      I was pleasantly surprised.
      I had to reinstall VirtualBox and a few other apps, but no issues so far.
      However, btop only shows one CPU but I read that version 1.3.0 has a bug about that. (EDIT!!! Pres 2-3-4 and then 2-3-4 again) Curious...
        i noticed kubuntu24.04.1LTS on kubuntu downloads anyone tried it yet?
          My laptop was installed with the kubuntu-24.04.1-desktop-amd64.iso.
          Very respectfully,
          James
            Do note that 24.04.1 is just an updated ISO image, with the current updates rolled in. Anyone using 24.04 is already there.
              I've now got an interesting error here with the laptop.
              The background refuses to come up! I an showing this using the external display. Both it and the laptop's display now show the same thing.
              Is this an easy fix?
              Picture:
                The wife's Dell Precision T5610 upgraded without issue.
                Now, back to the laptop...
                And, one more, my Dell T7910 to go but that will be in a month or so.
                  sigh
                  systemctl restart sddm
                  Then, I also did this:
                  systemctl enable sddm
                  Adding to my notes.
                  Ref URL:
                  https://bbs.archlinux.org/viewtopic.php?id=214709
                    Very respectfully,
                    James
                    How are you partitioning the hard drive?
                      I left the defaults.
                      Seems that after the firmware update, I have to run systemctl restart sddm now.
                        Perhaps this should resolve it:
                        log back in
                        do it again
                          log back in
                          do it again
                          Nope, seems that it is an ongoing "quirk" with the laptop and 24.04. Rebooting seems to work, but powered off and then restarting means I have to run the commands...
                          Even AFTER I have also had systemctl enable sddm entered.
                          Very, very odd.
