So this evening I turned on my wonderful, reliable laptop and two things happened. The mouse was unresponsive (but the touch pad worked and still works). Fixed the mouse.
The other is a bit more serious. While trying to look for errors during boot (to research the mouse problem), i opened Konsole and entered
It responded with
I can run dmesg with sudo, but I'm not sure what could have caused the change to REQUIRE sudo for dmesg. I think the only update yesterday noted by a system tray notice form Discover was a single python package - which I ran.
I have rebooted a couple of times. The mouse still works, but dmesg is still being obstreperous. Any ideas?
dmesg
dmesg: read kernel buffer failed: Operation not permitted
