Good day everyone.
I used boot repair yesterday and I can boot into my Kubuntu 24.04 system. However, I see that my external monitor doesn't work.
What have I tried so far:
- using the performance mode in Nvidian settings and rebooted
- reinstalling the kernel with the old command sudo apt-get install --reinstall linux-image-etc-etc
- purging nvidia*
- reinstalling nvidia driver with sudo ubuntu-drivers autoinstall
Every time rebooting. Unfortunately, it doesn't work. However, I see this output when installing the driver:
Which I've never seen before. I am also sure that I flagged the option to reinstall the kernel when using boot-repair. I have a separate /boot/efi partition and another separate /boot partition which I think are working good. The /boot partition was to me necessary to use my devices that otherwise cannot boot. This /boot partition is in the internal SSD.
Any suggestions? Thanks in advance.
- purging nvidia*
nvidia-drm.ko: OK nvidia-modeset.ko: OK nvidia-peermem.ko: OK nvidia-uvm.ko: OK nvidia.ko: OK [B]depmod: FATAL: could not load /boot/System.map-6.8.0-31-generic: No such file or directory[/B] Configurazione di nvidia-kernel-source-535 (535.171.04-0ubuntu2)... Configurazione di nvidia-settings (510.47.03-0ubuntu4)... Configurazione di nvidia-utils-535 (535.171.04-0ubuntu2)... Configurazione di linux-modules-nvidia-535-generic (6.8.0-31.31)... Configurazione di nvidia-driver-535 (535.171.04-0ubuntu2)... Elaborazione dei trigger per initramfs-tools (0.142ubuntu25)... update-initramfs: Generating /boot/initrd.img-6.8.0-31-generic
