It happens that I am trying to delete a network interface, in this case the one in the attached image called 'Julio César'. As you can see, it appears in the list of networks in the tray, but if I then go to the network connections configuration, this 'Julio César' network does not appear, so I cannot delete it as I would wish.
Until yesterday, it did appear in the network connections, then I clicked on delete and it gave an error that I don't remember now but that basically said that it had not been possible to delete it. The fact is that it was deleted from the network connections window, but not from the network list in the tray, as can also be seen in the attached image.
On the other hand... could someone tell me what is this network called 'lo' that appears and that does not let me delete? Is this normal? And I would also like to know why the network interface called 'Conexión cableada' does not appear in the list of networks in the tray.
Thanks and greetings...
