SOLVED Hauppage PCI tuner drops out.
    [SOLVED] SOLVED Hauppage PCI tuner drops out.
    I recently upgraded to Noble 24.04 from Jammy 22.04 and the Hauppauge quad PCI tuner drops out after about 1/2 hour or so.
    I can bring it back online with this script I cobbled together from various sources on PCI issues, but it isn't a lot of good with a tv tuner set for automatic recording!
    echo "1" > /sys/bus/pci/devices/0000:07:00.0/remove
    sleep 2
    echo "1" > /sys/bus/pci/rescan
    echo "2" > /sys/bus/pci/devices/0000:08:00.0/remove
    sleep 2
    echo "2" > /sys/bus/pci/rescan​
    The system worked well for a couple of years on Jammy.
    This is the result of a PCI scan:-​
    tony@linuxmint:~$ lspci
    00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
    00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05)
    00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) (rev 05)
    00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
    00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
    00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
    00:1b.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #17 (rev f0)
    00:1b.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #21 (rev f0)
    00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #1 (rev f0)
    00:1c.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0)
    00:1c.6 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #7 (rev f0)
    00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #9 (rev f0)
    00:1f.0 ISA bridge: Intel Corporation 200 Series PCH LPC Controller (Z270)
    00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
    00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
    00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
    00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V
    01:00.0 VGA compatible controller: NVIDIA Corporation TU116 [GeForce GTX 1660] (rev a1)
    01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
    01:00.2 USB controller: NVIDIA Corporation TU116 USB 3.1 Host Controller (rev a1)
    01:00.3 Serial bus controller: NVIDIA Corporation TU116 USB Type-C UCSI Controller (rev a1)
    02:00.0 Non-Volatile memory controller: SK hynix PC401 NVMe Solid State Drive 256GB
    03:00.0 Non-Volatile memory controller: Micron/Crucial Technology P2 [Nick P2] / P3 / P3 Plus NVMe PCIe SSD (DRAM-less) (rev 01)
    04:00.0 Non-Volatile memory controller: Phison Electronics Corporation E12 NVMe Controller (rev 01)
    05:00.0 PCI bridge: Pericom Semiconductor PI7C9X2G304 EL/SL PCIe2 3-Port/4-Lane Packet Switch (rev 05)
    06:01.0 PCI bridge: Pericom Semiconductor PI7C9X2G304 EL/SL PCIe2 3-Port/4-Lane Packet Switch (rev 05)
    06:02.0 PCI bridge: Pericom Semiconductor PI7C9X2G304 EL/SL PCIe2 3-Port/4-Lane Packet Switch (rev 05)
    07:00.0 Multimedia video controller: Conexant Systems, Inc. CX23887/8 PCIe Broadcast Audio and Video Decoder with 3D Comb (rev 04)
    08:00.0 Multimedia video controller: Conexant Systems, Inc. CX23887/8 PCIe Broadcast Audio and Video Decoder with 3D Comb (rev 04)
    09:00.0 USB controller: ASMedia Technology Inc. ASM2142/ASM3142 USB 3.1 Host Controller
    0a:00.0 USB controller: ASMedia Technology Inc. ASM2142/ASM3142 USB 3.1 Host Controller
    0b:00.0 Non-Volatile memory controller: Micron/Crucial Technology P2 [Nick P2] / P3 / P3 Plus NVMe PCIe SSD (DRAM-less) (rev 01)
    tony@linuxmint:~$​
    Hardware: Asus STRIX Z270E GAMING v: Rev 1.xx serial: 170706774500147 Mobo.
    Bios UEFI: American Megatrends v: 1302 date: 03/15/2018
    CPU Intel I7, 16gb ram
    GPU Nvidia GTX1660
    Hauppauge Quad Win-tv model 01607 as here:https://www.hauppauge.co.uk/site/pro...ta_quadhd.html
    I know the system is getting a bit old, but it has worked well until Noble Numbat.
    Any suggestions very welcome.​
    Tony
    Asus Z270i7 16gb rm 8tb GT1660 Haupp Quad tuner Kubuntu Jammy/Win 11 Be/FE mythtv 0.34Homerun dual netwk tuner 55¨ Smsng QN95B55" Lap Smsng NP R580 i5 nvidia linux Ultimate/Win 10
    Tony
    I am big believer in the "if it ain't broke don't fix it" method. If there is no critical software needed in the new version then go with what works the old OS.
      I agree but the problem I have found with that approach is that eventually support runs out and you are left with a vulnerable system with no updates and security holes. I use this machine as my everyday desktop as well as an HTPC. If it were a stand-alone HTPC I wouldn't care so much, it could be ten years out of date but not for my daily usage.
        With the Ubuntu Pro extended support now available that is less of a worry for the next ten or so years, even with the standard support of five years you have until 2027.
          I found a solution. The line
          pci=noacpi
          In grub will sort this.
          How do I mark it as solved? Not obvious.
            Edit the first post (click the Edit link). Then choose SOLVED from the drop down list to to the left of the Thread Title.
