Upgrade Kubuntu from 23.04 to 23.10 - hangs
    Following a complex issue due to a too small /boot. I tried again to upgrade.
    It ran for a very long while, ending in:
    update-initramfs: deferring update (trigger activated)
    Sourcing file `/etc/default/grub'
    Generating grub configuration file ...
    Found linux image: /boot/vmlinuz-6.5.0-10-generic
    Found linux image: /boot/vmlinuz-6.2.0-36-generic
    Found initrd image: /boot/initrd.img-6.2.0-36-generic
    Found linux image: /boot/vmlinuz-6.2.0-35-generic
    Found initrd image: /boot/initrd.img-6.2.0-35-generic
    Found memtest86+x64 image: /boot/memtest86+x64.bin
    Warning: os-prober will be executed to detect other bootable partitions.
    Its output will be used to detect bootable binaries on them and create new boot entries.
    Just before this a popup appeared saying a filesystem was not responding ...
    So after being hung for about an hour , I had to shut the system down .... at reboot it failed:
    Kernel Panic .... Unable to mount root fs on unknown-block(0,0) ....
    Likely the initrd (or similar) was not setup (given where it hung)
    As a happy accident, due to my earlier issues with /boot, I had a whole alternate partition with boot loader that was able to boot
    (old kernel vmlinuz-6.2.0-36-generic) and was able to run:
    sudo dpkg --configure -a
    (I didn't guess, I got prompted
    E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
    This ran for a while, the the same popup and again it hung:
    Configuring grub-pc
    A new version (/tmp/grub.f9D62sso8z) of configuration file /etc/default/grub is available, but the version installed
    currently has been locally modified.
    1. install the package maintainer's version 5. show a 3-way difference between available versions
    2. keep the local version currently installed 6. do a 3-way merge between available versions
    3. show the differences between the versions 7. start a new shell to examine the situation
    4. show a side-by-side difference between the versions
    What do you want to do about modified configuration file grub? 1
    Replacing config file /etc/default/grub with new version
    Found initrd image: /boot/initrd.img-6.5.0-10-generic
    My guess was it was the automounted NFSv3 filesystems. This time I could not even shut it down:
    init 6 failed , shutdown -n now , hung just before poweroff... so powerswitch
    Again brought up using the alternate partition.
    This time before attempting the dpkg --configure -a , I did:
    systemctl stop autofs
    systemctl stop nfs-client.target
    And also disabled Wifi (vi GUI) [ As recommended the system had mains power and wired Ethernet throughout ]
    Again kicked off :
    In the middle a couple of popups appeared that the Ethernet had disconnected & reconnected
    And this time it completed cleanly.
    So, if I were to guess I'd say the networking was stopped using the package reconfigure and this caused the whole process the hang (due of NFSv3 mounts blocking)
