Wayland - ibus warning messages
    Just got round to upgrading from 23.04 to 23.10. I switched to Wayland to check it out. On logging in I get the following 2 warning messages;
    1) IBus should be called from the desktop session in Wayland. For KDE, you can launch 'systemsettings5' utility and go to "Input Devices" -> "Virtual Keyboard" section and select "IBus Wayland" icon and click "Apply" button to configure IBus in Wayland. For other desktop sessions, you can copy the 'Exec=' line in org.freedesktop.IBus.Panel.Wayland.Gtk3.desktop file to a configuration file of the session. Please refer each document about the "Wayland input method" configuration. Before you configure the "Wayland input method", you should make sure that QT_IM_MODULE and GTK_IM_MODULE environment variables are unset in the desktop session.
    2) Please unset QT_IM_MODULE and GTK_IM_MODULE environment variables and 'ibus-daemon --panel disable' should be executed as a child process of ibus-ui-gtk3 component.​
    Setting the Virtual Keyboard in System Settings was OK but how do you unset the environment variables and how do you execute 'ibus-daemon --panel disable' as a child process of ibus-ui-gtk3 component. 🤔
    Other than having to re-configure the desktop to make it more readable for me, wayland seems to be running OK so far.
    Jim!
    Same issue here, hasn't affected functionality, but because I am trying to be a good boy and follow the directions, I am trying to sort it out.
    First of all, I get no messages when using X11. On Wayland, I was only getting the first message. So I changed the virtual keyboard message and added a bash script to autostart which simply unset the variables:
    unset GTK_IM_MODULE
    unset QT_IM_MODULE
    After that, the first longer message went away, and I started getting the second message there.
    Then, following suggestions I saw elsewhere, I tried to do this on the script:
    unset GTK_IM_MODULE
    unset QT_IM_MODULE
    ibus-daemon --panel disable &​
    kept getting message number 2.
    then i tried another suggestion, which was to add that to /etc/environment, but still no dice for me. I guess I am ignoring the message for now, since everything actually works properly. Just wondering what's the deal mostly
      PS.: Since the message also says
      I went and checked what that was, which was set to:
      Exec=/usr/libexec/ibus-ui-gtk3 --enable-wayland-im --exec-daemon --daemon-args "--xim --panel disable"
      Which seems to be how you would "executed as a child process of ibus-ui-gtk3"
        Here's what I actually did to remove this warning as I initially had no idea how and where to use the "unset" command.
        I added the two lines
        unset GTK_IM_MODULE
        unset QT_IM_MODUL​E
        as the last entries in ~/.profile
        ​I added the following single line
        as the last entry in the [General] section of ~/.config/ksmserverrc
        Now all is OK. The warning makes a presumption that you have an intimate knowledge of what environment variables are and that you know what things like a "child process" are. 🙂
        Jim!
