Please do not use the CODE tag when pasting content that contains formatting (colored, bold, underline, italic, etc).
The CODE tag displays all content as plain text, including the formatting tags, making it difficult to read.
System Settings > Startup and Shutdown > Login Screen (SDDM) and uncheck Automatically log in:
To add a new user: System Settings > Users and click on Add New User
AFAIK, the "Guest Account" or more properly "Guest Session" doesn't really exist anymore. You could try this: https://gist.github.com/michel-zimme...2a3e631f6c9392 but it's based on 16.04 and I have no idea if it would work now.
You can do a web search and find 100's of posts asking about how to enable a guest session dating back to 2016 but all I could find was complaints that it no longer existed and even a bug report on SDDM as a regression that needed to be fixed.
From what I can find, only LightDM still supports guest sessions. I took the simple route and just made a user account called Guest and gave it the password guest. You could just switch to LightDM and be good to go, or create a guest account and have it automatically wipe itself on each log out. You probably would want to set it as passwordless also. Self-wiping would be really simple of you use BTRFS. You could simply create the guest account and have it's home in a subvolume. Then on log-out, delete the subvolume and restore it from a "clean" snapshot.
I think what you will want to do will depend on how often you expect a guest user to use the system. I my case it was rarely so I didn't bother wiping it after each user.
