[SOLVED] Kubuntu 22.04 Samsung HDD ntfs mount point disappears?
    ***Solution is noted at the end of post*** (I put this in the wrong forum, thank you for your patience and understanding)
    I had just accessed this former Windows 7 NTFS 2tb hdd drive, came back later to find.
    Click image for larger version  Name:	image.png Views:	0 Size:	56.9 KB ID:	674253
    I looked for the mount point /media/unity/MAINDRIVE to find it was missing, along with HP-Recovery (which I think that one was never mounted anyway) *this is not a dual boot system. here mount shown missing via lsblk -f ..
    [CODEsdb
    ├─sdb1
    │ ntfs SYSTEM E0980FA0980F7476 74.8M 25% /media/unity/SYSTEM
    ├─sdb2
    │ ntfs MAIN DRIVE
    │ 0E683B55683B3AB3
    ├─sdb3
    ├─sdb4
    │ ntfs HP_RECOVERY
    │ 9C50A5F050A5D0F6
    └─sdb5
    ntfs New Volume
    DA129EB3129E93DB 97.6G 0% /media/unity/New Volume
    ​ CODE]
    I created another mount point at /media/unity/MAINDRIVE and edited fstab (even though in times past, it just mounted the drive) and tried to mount it and got error.
    [CODE
    Error opening read-only '/dev/sdb2': Permission denied
    Failed to mount '/dev/sdb2': Permission denied
    Please check '/dev/sdb2' and the ntfs-3g binary permissions,
    and the mounting user ID. More explanation is provided at
    https://github.com/tuxera/ntfs-3g/wiki/NTFS-3G-FAQ
    ​ CODE]
    This is all of the sudden unexpected behavior, and my first thought was a wire loosened up on the HDD. However when I look into the hardware devices, it sees the drive. Is anyone familiar with this behavior? The searches I have done online are far off in similarities, leaving me without sound clues, and making me bunny trail. As always your tutor-age is appreciated. (Trying to use code brackets to keep the read outs clean and readable, but do not know if I have done it correctly?)
    EDITed to add info....
    [CODE sudo fdisk -l /dev/sdb
    Disk /dev/sdb: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
    Disk model: Hitachi HDS72302
    Disklabel type: dos
    Disk identifier: 0x52a2d054
    Device Boot Start End Sectors SizeIdType
    /dev/sdb1 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
    /dev/sdb2 206911 3678771199 3678564289 1.7T 7 HPFS/NTFS/exFAT
    /dev/sdb3 3678771200 3883571199 204800000 97.7G f W95 Ext'd (LBA)
    /dev/sdb4 * 3883571200 3907027119 23455920 11.2G 7 HPFS/NTFS/exFAT
    /dev/sdb5 3678773248 3883571199 204797952 97.7G 7 HPFS/NTFS/exFAT
    Partition table entries are not in disk order.
    ​ CODE]
    I got a clue from gParted when it said use Windows chkdsk, which led me to NTFS-3G, which was already installed on Kubuntu 22.04.
    sudo ntfsfix /dev/sdb2 (was the code that fixed it)
    sudo apt-get install ntfs-3g (if you need to install it)
    my results, the important one it fixed, the other one has bad sectors.
    [CODE] sudo ntfsfix /dev/sdb2
    Mounting volume... $MFTMirr does not match $MFT (record 3).
    FAILED
    Attempting to correct errors...
    Processing $MFT and $MFTMirr...
    Reading $MFT... OK
    Reading $MFTMirr... OK
    Comparing $MFTMirr to $MFT... FAILED
    Correcting differences in $MFTMirr record 3...OK
    Processing of $MFT and $MFTMirr completed successfully.
    Setting required flags on partition... OK
    Going to empty the journal ($LogFile)... OK
    Checking the alternate boot sector... OK
    NTFS volume version is 3.1.
    NTFS partition /dev/sdb2 was processed successfully.
    sudo ntfsfix /dev/sdb3
    [sudo] password for unity:
    Mounting volume... NTFS signature is missing.
    FAILED
    Attempting to correct errors... NTFS signature is missing.
    FAILED
    Failed to startup volume: Invalid argument
    Trying the alternate boot sector
    Unrecoverable error
    Volume is corrupt. You should run chkdsk.
    ​ [CODE]
