How to use Superkey in Kubuntu 22.04 LTS
    How do I set Superkey or Meta key to open my Menu? I am using Kubuntu 22.04.2 LTS Superkey currently does nothing by default settings.
    Try this.
      Or...
      I did this 'just now' on my 23.04 system. System Settings > Hardware > Input Devices > Keyboard > Advanced
      Check Configure keyboard options
      Expand Alt and Win behavior
      Select Menu is mapped to Win
      Click Apply
      Works.
        Which can be found here:
          Thanks guys, right clicking on the launcher icon and clicking Superkey + F1 solved the issue. It should be the default setting on Kubuntu tbh.
            it is, in both Plasma and Kubuntu. I think you just had a somewhat common bug that some people experience, and doesn't seem to be an issue in current Plasma versions.
