USB laserprinter issue (no color) Kyocera M5521cdw
    I had this printer in use for a couple of years installation as a network printer was easy, but since it is connected via USB and the 22.10 update, I am having some issues. Depending on which driver I use I either get the "Filter failed" error or there is no more color on the page.
    Have you tried their Driver for linux? https://www.kyoceradocumentsolutions...tml#tab=driver
    And Welcome to the forum.
      Thanks! Yes, that download contains a PPD file for the printer model which I have added to my systems PPD files and which I have installed.
