Sound sometimes stops or switches unpugged headphones
    I am using an AMD system.
    System:
    Kernel: 5.19.0-24-generic arch: x86_64 bits: 64 compiler: N/A
    Desktop: KDE Plasma v: 5.25.5 Distro: Ubuntu 22.10 (Kinetic Kudu)
    Machine:
    Type: Desktop Mobo: ASUSTeK model: M5A97 EVO v: Rev 1.xx serial: <filter>
    UEFI: American Megatrends v: 1604 date: 10/16/2012
    CPU:
    Info: 6-core model: AMD Phenom II X6 1090T bits: 64 type: MCP arch: K10
    rev: 0 cache: L1: 768 KiB L2: 3 MiB L3: 6 MiB
    Speed (MHz): avg: 1600 high: 3200 min/max: 800/3200 boost: enabled cores:
    1: 800 2: 3200 3: 800 4: 800 5: 3200 6: 800 bogomips: 38526
    Flags: ht lm nx pae sse sse2 sse3 sse4a svm
    Graphics:
    Device-1: AMD Barts LE [Radeon HD 6790] vendor: XFX Pine driver: radeon
    v: kernel arch: TeraScale-2 bus-ID: 01:00.0
    Display: x11 server: X.Org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver:
    X: loaded: radeon unloaded: fbdev,modesetting,vesa gpu: radeon
    resolution: 1280x1024~75Hz
    OpenGL: renderer: AMD BARTS (DRM 2.50.0 / 5.19.0-24-generic LLVM 15.0.2)
    v: 3.3 Mesa 22.2.1 direct render: Yes
    Audio:
    Device-1: AMD SBx00 Azalia vendor: ASUSTeK M4A89GTD PRO/USB3
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2
    Device-2: AMD Barts HDMI Audio [Radeon HD 6790/6850/6870 / 7720 OEM]
    vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
    Sound Server-1: ALSA v: k5.19.0-24-generic running: yes
    Sound Server-2: PulseAudio v: 16.1 running: no
    Sound Server-3: PipeWire v: 0.3.58 running: yes
    Network:
    Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
    port: d000 bus-ID: 02:00.0
    IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Drives:
    Local Storage: total: 1.58 TiB used: 43.03 GiB (2.7%)
    ID-1: /dev/sda model: SATA SSD size: 223.57 GiB
    ID-2: /dev/sdb vendor: Seagate model: ST1000DM003-1SB10C size: 931.51 GiB
    ID-3: /dev/sdc vendor: Western Digital model: WD5000AAKS-00UU3A0
    Partition:
    ID-1: / size: 218.51 GiB used: 43.03 GiB (19.7%) fs: ext4 dev: /dev/sda2
    ID-2: /boot/efi size: 511 MiB used: 5.2 MiB (1.0%) fs: vfat
    dev: /dev/sda1
    Swap:
    ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
    Sensors:
    System Temperatures: cpu: 49.0 C mobo: N/A gpu: radeon temp: 46.5 C
    Fan Speeds (RPM): N/A
    Info:
    Processes: 247 Uptime: 1h 23m Memory: 7.73 GiB used: 2.92 GiB (37.9%)
    Init: systemd target: graphical (5) Compilers: gcc: 12.2.0 Packages: 2546
    Shell: Sudo v: 1.9.11p3 inxi: 3.3.21
    Here is my HW details.
    Sound systems stops suddenly.
    When I go to "Audio -System settings" using KDE menu .
    I see sometimes system switched to "Headphones (unplugged).
    I see sometimes system is on "Line out" (which is normal output) but no sound. Then I switch to headphones (unpugged) then back line out sound starts to play.
    Any idea to fix the problem.
    Below 2 screenshots of Audio - System Settings screen
