Hi to all,
I am having a problem with mergerfs. I have laptop with two disks (NVMe SSD). Two disks are mounted in
as
(511GB and 24 258files)
and
(849GB and 234 598 files)
When accessing them in these locations there is no problem listing files in Dolphin, everything goes lightning fast.
The problem occurs when I combine them in pool with mergerfs with the following command
The problem is that when I am using Dolphin it goes unusable while trying to list
There is no problem while using Midnight Commander in the same directory.
I have tried combination of options while mounting with mergerfs, every time the result is the same.
What I have found on internet is that Dolphin have some problems with FUSE mounts.
If someone have similar problem and manage to solve it please tell me.
/mnt
/mnt/drive1
and
/mnt/drive2
sudo /usr/bin/mergerfs -o allow_other,cache.files=partial,dropcacheonclose=t rue,cache.writeback=true,cache.statfs=true,cache.s ymlinks=true,cache.readdir=true,readahead=1024 /mnt/drive1:/mnt/drive2 /media/Media
/media/Media
