Fresh Kubuntu 22.04.1 install and VirtualBox problems
    SSD erased (Solid State Drive)
    A clean start - done on purpose.
    Kubuntu 22.04.1 LTS (Jammy Jellyfish)
    was installed
    Kubuntu updated
    Kubuntu upgraded
    restart computer
    Kubuntu_Discover installs VirtualBox 6.1.38
    and
    confirming 6.1.38 is current at
    https://www.virtualbox.org/wiki/Linux_Downloads
    virtualbox-6.1_6.1.38-153438_Ubuntu_jammy_amd64.deb
    then
    Import appliance .ova file
    run VirtualBox
    virtualbox message is
    Kernel driver not installed (rc=-1908)
    details:
    The VirtualBox Linux kernel driver is
    either not loaded or not set up correctly.
    Please reinstall virtualbox-dkms package and
    load the kernel module by executing
    'modprobe vboxdrv'
    as root.
    If your system has EFI Secure Boot enabled
    you may also need to sign the kernel modules
    (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them.
    Please see your Linux system's documentation for more information.
    where: suplibOsInit what:
    3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) -
    The support driver is not installed. On linux, open returned ENOENT.
    one suggestion to fix problem, manually install
    Oracle_VM_VirtualBox_Extension_Pack-6.1.38.vbox-extpack
    same problem.
    many web pages visited
    many suggestions applied
    same problem.
    What to do?
    'modprobe vboxdrv'
    as root.
    So, have you installed the package as requested, or checked that it is installed?
    sudo apt reinstall virtualbox-dkms​ it probably won't show in Discover as the package is not a GUI application itself.
    This builds the needed kernel modules for Virtualbox, and this will also show any errors that may have occurred
    It *should* load the drivers (I might be wrong here), but you probably need a reboot, but you can try loading them manually as described, if there were no errors or anything.
    sudo modprobe vboxdrv​
      Reading package lists... Done
      Building dependency tree... Done
      E: Unable to locate package virtualbox-dkms
      modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.15.0-48-generic
      What to do?
        What to do?
        No idea.
        same problem.
        ​These may be part of the problem, possibly. No idea what you did​
        You should have virtualbox-dkms in 22.04, I sure do
        $ apt policy virtualbox
        virtualbox:
        Installed: (none)
        Candidate: 6.1.38-dfsg-3~ubuntu1.22.04.1
        Version table:
        6.1.38-dfsg-3~ubuntu1.22.04.1 500
        500 http://archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 Packages
        6.1.32-dfsg-1build1 500
        500 http://archive.ubuntu.com/ubuntu jammy/multiverse amd64 Packages
        ​and
        $ apt policy virtualbox-dkms
        virtualbox-dkms:
        Installed: (none)
        Version table:
        You said that you installed virtualbox using discover.
        Did you download and install files from the Virtualbox website, or use the native packages found in Discover?
        Without knowing *exactly* what you did in both installing and then trying to fix things, it will be hard to give proper advice on what to do.
          virtualbox-dkms should have been installed when you install Virtualbox through Discover, as it is identified as a dependency package. However, that the command sudo apt reinstall virtualbox-dkms returns E: Unable to locate package virtualbox-dkms indicates that it isn't installed. So, in the konsole, run: sudo apt install virtualbox-dkms
            running reinstall would just install it, if not present.
            I just tested to verify.
            The error is saying the OP does not have it available to be installed to begin with, so there is something amiss, or other repos added for VB
            For example, the repo from Virtualbox themselves doesn't use separate packaging for things like the DKMS stuff iirc, However, the package would still show up in an apt search, just not be installable.
              No idea.
              virtualbox:
              Installed: (none)
              Version table:
              ​and
              virtualbox-dkms:
              Installed: (none)
              Version table:
              virtualbox:
              Installed: 6.1.38-dfsg-3~ubuntu1.22.04.1
              Version table:
              *** 6.1.38-dfsg-3~ubuntu1.22.04.1 500
              500 http://ca.archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 Packages
              100 /var/lib/dpkg/status
              500 http://ca.archive.ubuntu.com/ubuntu jammy/multiverse amd64 Packages
              virtualbox-dkms:
              Version table:
              > use the native packages found in Discover?​
              Used native packages found in Discover.
              Suggestions?
                output of dkms status and uname -r ?
                  [sudo] password for x:
                  virtualbox-dkms is already the newest version (6.1.38-dfsg-3~ubuntu1.22.04.1).
                    output of
                    Warning: I do not know how to handle uname.
                      dkms status
                      uname -r
                        dkms status
                        uname -r
                        dkms status
                        virtualbox/6.1.38, 5.15.0-48-generic, x86_64: installed
                        uname -r
                        5.15.0-48-generic
                          That looks normal. Do you have the headers installed for that kernel?
                            Unsure what above means.
                            What is the command to display headers? or
                            What to click on, drill down on, to display headers?
                            What is the command to display kernel?
                              linux-headers-5.15.0-48-generic - Linux kernel headers for version 5.15.0 on 64 bit x86 SMP
                              Command:
                              sudo apt install linux-headers-5.15.0-48-generic​
                              Then you will probably need to reconfigure the dkms module.
