Some annoying bugs in Ubuntu Studio 22.04
    Good morning,
    After a lot of trouble concerning Kubuntu 22.04, NVidia (probably) and a Wacom tablet, I have made the transition to Ubuntu STudio 22.04. Which probably is not much more than Kubuntu with creative software but a fine KDE-distro nonetheless. However, sometimes when I am at the startup screen, the cursor for typing simply disappears and I cannot type, or do anything whatsoever. The only thing I can do then is a hard reset. After the startup a similar situation can occur. The starter menu won't respond to a mouseclick and anything else won't respond either. Luckily ctrl-alt-del still works so I can shut down the system properly and start again. What can I do to fix this?
    GPU: Geforce RTX 3070 driver 535 proprietary.
