Kubuntu 22.04 Upgrade message
    Hello folks!
    I get the following message while upgrading Kubuntu 22.04, which I don't understand what "Ubuntu Pro with esm-apps" means. Need help here. thank you!
    marco@t540p:~$ sudo apt full-upgrade
    Reading package lists... Done
    Building dependency tree... Done
    Calculating upgrade... Done
    Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
    vlc-plugin-qt libvlc5 python2.7-minimal vlc-data libvlccore9 vlc imagemagick
    libavcodec-extra vlc-bin vlc-l10n libopenexr25 libpostproc55
    libmagickcore-6.q16-6-extra vlc-plugin-samba libmagickwand-6.q16-6
    libavcodec-extra58 libpython2.7 vlc-plugin-notify libavutil56
    imagemagick-6.q16 libswscale5 libeditorconfig0 libmagickcore-6.q16-6
    vlc-plugin-access-extra vlc-plugin-skins2 vlc-plugin-video-splitter
    libswresample3 imagemagick-6-common vlc-plugin-video-output libavformat58
    python2.7 libpython2.7-minimal libvlc-bin libpython2.7-stdlib
    vlc-plugin-base vlc-plugin-visualization libavfilter7
    Learn more about Ubuntu Pro at https://ubuntu.com/pro
    marco@t540p:~$
    It is an 'advertisement' of sorts. The url there describes it.
    LTS users can opt in to Ubuntu Pro, which offers security fixes for a broader set of packages, for longer (10 years!), on things that normally aren't actually supported by Ubuntu/Canonical directly - the so-called Universe section of the repos that has on\y ever had volunteer community support.
    It is free for personal use on up to 5 machines
    A reasonable and more user-friendly summary HERE including ways to remove the message, if desired.
      Thank you!
