Upgrading from Kubuntu 20.04 LTS to 22.04 LTS
    I tried upgrading my Kubuntu 20.04 using: sudo do-release-upgrade and got the following failure
    ​sudo do-release-upgrade
    [sudo] password for vgharris:
    Checking for a new Ubuntu release
    Traceback (most recent call last):
    File "/usr/bin/lsb_release", line 95, in <module>
    main()
    File "/usr/bin/lsb_release", line 59, in main
    distinfo = lsb_release.get_distro_information()
    File "/usr/lib/python3/dist-packages/lsb_release.py", line 398, in get_distro_informat
    ion
    distinfo = guess_debian_release()
    File "/usr/lib/python3/dist-packages/lsb_release.py", line 288, in guess_debian_releas
    e
    get_distro_info(distinfo['ID'])
    File "/usr/lib/python3/dist-packages/lsb_release.py", line 48, in get_distro_info
    RELEASES_ORDER.sort(key=lambda n: float(n[0]))
    File "/usr/lib/python3/dist-packages/lsb_release.py", line 48, in <lambda>
    ValueError: could not convert string to float: '6.06 LTS'
    main()
    ion
    e
    main()
    ion
    e
    lsb_release returned exitcode: 1
    main()
    ion
    e
    There is no development version of an LTS available.
    To upgrade to the latest non-LTS development release
    set Prompt=normal in /etc/update-manager/release-upgrades.
    vgharris@ST2000DM001-1ER164:~$
    ​I don't really want a non-LTS version. Do you have any recommendations?
    Make sure you are fully up to date with apt, and have no errors or anything there, and try the official instructions, to see if there is any difference.
    https://help.ubuntu.com/community/JammyUpgrades/Kubuntu
    The instruction given is the same for 20.04-22.04 upgrades, and the commands provided are a little different that what you used.
    Provide the outputs of cat /etc/lsb-release and cat /usr/lib/os-release, I wonder if there is an issue with your lsb_release info.
    20.04 is still alive and supported by Ubuntu, (except for Kubuntu-related updates to Plasma). You won't be able to upgrade to a non-LTS release, nor to an End -of-Life release, so the only path is to 22.04.
      Thanks for your help! Here are the results you asked for. I don't see anything about Kubuntu.
      vgharris@ST2000DM001-1ER164:~$ cat /etc/lsb-release and cat /usr/lib/os-release
      DISTRIB_ID=Ubuntu
      DISTRIB_RELEASE=20.04
      DISTRIB_CODENAME=focal
      DISTRIB_DESCRIPTION="Ubuntu 20.04.5 LTS"
      cat: and: No such file or directory
      cat: cat: No such file or directory
      PRETTY_NAME="Deepin 15"
      NAME="Deepin"
      VERSION_ID="15.11"
      VERSION="15.11"
      ID=deepin
      HOME_URL="https://www.deepin.org/"
      BUG_REPORT_URL="http://feedback.deepin.org/feedback/"
      ​Respectfully,
      vgharris
        That should be two separate commands:
        and
        cat /usr/lib/os-release​
        Though I think you are showing the content of both files, as requested
        You won't , since Kubuntu is Ubuntu. They are not separate distros.
        NAME="Deepin"
        VERSION_ID="15.11"
        VERSION="15.11"
        ID=deepin
        But I have no idea why you have Deepin stuff in there. that isn't even Ubuntu, but based on Debian.
        I am sure that if this is a mixed system somehow, this would easily break things like this, due to mixed components, and likely missing items.
          But I have no idea why you have Deepin stuff in there. […]
          vgharris: the output of sudo apt update in Konsole could also give us some clues (if you post it here, please use CODE tags).
