Now I did some digging around and found that using Grub Customizer causes some issues when upgrading.
I have tried reinstalling Grub Customizer and removing "half-installed" from 5.11.0-38 in /var/lib/dpkg/status but both of suggested solutions failed.
This is what I get when trying to update and upgrade:
TLDR.... HALP!!!
Hope everyone has been well
I haven't had my computer set up for almost 2 years and I'm updating everything.
I figured I'd have at least a little fun
sudo apt-get update && sudo apt-get upgrade Hit:1 http://us.archive.ubuntu.com/ubuntu jammy InRelease Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease Hit:3 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease Hit:4 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease Hit:5 https://repo.steampowered.com/steam stable InRelease Hit:6 https://ppa.launchpadcontent.net/danielrichter2007/grub-customizer/ubuntu jammy InRelease Reading package lists... Done Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: hwinfo libffi7 libhd21 libobjc-9-dev libx86emu3 linux-image-5.8.0-48-generic linux-modules-5.8.0-48-generic Use 'sudo apt autoremove' to remove them. The following packages will be REMOVED: linux-image-5.11.0-38-generic linux-image-5.11.0-46-generic linux-image-5.13.0-28-generic The following packages will be upgraded: gcc-10-base gcc-10-base:i386 2 upgraded, 0 newly installed, 3 to remove and 0 not upgraded. 3 not fully installed or removed. Need to get 0 B/42.9 kB of archives. After this operation, 32.2 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 410565 files and directories currently installed.) Removing linux-image-5.11.0-38-generic (5.11.0-38.42~20.04.1) ... /etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting /boot/initrd.img-5.11.0-38-generic /etc/kernel/postrm.d/zz-update-grub: Sourcing file `/etc/default/grub' Sourcing file `/etc/default/grub.d/init-select.cfg' Generating grub configuration file ... Found theme: /boot/grub/themes/tela/theme.txt Found linux image: /boot/vmlinuz-6.2.0-34-generic Found initrd image: /boot/initrd.img-6.2.0-34-generic Found linux image: /boot/vmlinuz-5.15.0-86-generic Found initrd image: /boot/initrd.img-5.15.0-86-generic Found linux image: /boot/vmlinuz-5.15.0-84-generic Found initrd image: /boot/initrd.img-5.15.0-84-generic Found linux image: /boot/vmlinuz-5.8.0-48-generic Found initrd image: /boot/initrd.img-5.8.0-48-generic Found linux image: /boot/vmlinuz-5.8.0-45-generic Found initrd image: /boot/initrd.img-5.8.0-45-generic Found linux image: /boot/vmlinuz-5.8.0-44-generic Found initrd image: /boot/initrd.img-5.8.0-44-generic /etc/grub.d/bin/grubcfg_proxy: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127 dpkg: error processing package linux-image-5.11.0-38-generic (--remove): installed linux-image-5.11.0-38-generic package post-removal script subprocess returned error exit status 1 dpkg: too many errors, stopping Errors were encountered while processing: linux-image-5.11.0-38-generic Processing was halted because there were too many errors. E: Sub-process /usr/bin/dpkg returned an error code (1)[/FONT]
