Two Kubuntu locations?
    [RESOLVED] Two Kubuntu locations?
    My box has been booting very slowly, even though I have it set to ultrafast boot. I've done some poking around and found some one thing to make grub faster (setting one line to "quiet"). When I updated grub2, I got what seem to me to be strange lines on the output:
    Found Ubuntu 22.04.2 LTS (22.04) on /dev/nvme0n1p3
    Found Ubuntu 22.04.2 LTS (22.04) on /dev/sda5
    ​Shouldn't 22.04 be in only one place? Are there two installations somehow fighting with each other? I don't know what I'm looking at, and I'm sure there is additional information that I should furnish. Would someone please let me know what I should do/provide at this point?
    Thanks.
    DO you have two drives? Maybe an NVME and an SSD? Ppost the contents of your /etc/fstab.
      I do, but the OS shouldn't be on both. Here's /etc/fstab:
      # Use 'blkid' to print the universally unique identifier for a
      # device; this may be used with UUID= as a more robust way to name de
      vices
      # that works even if disks are added and removed. See fstab(5).
      # <file system> <mount point> <type> <options> <dump> <pass
      # / was on /dev/sda2 during installation
      UUID=d6cc9de0-f209-45bb-b0b8-68a75ef42e3e / ext4 err
      ors=remount-ro 0 1
      # /boot/efi was on /dev/nvme0n1p2 during installation
      UUID=38BA-F449 /boot/efi vfat umask=0077 0 1
      # /home was on /dev/sda4 during installation
      UUID=f9cc9e42-b1df-4619-8287-de078eb92257 /home ext4 def
      aults 0 2
      # swap was on /dev/sda3 during installation
      UUID=0e6d0318-717f-475b-8706-8e971e4a894d none swap sw
      0 0
      ​I see it, but I don't know how to decipher it.
        Actually we need to see the actual partitions on both drioves, irrespective of what is in the fstab
        I am betting that both drives have an EFI directory, and can I assume that you have installed Kubuntu on each in the past?
        Another possibility is that the bios simply hasn't forgotten an old install, maybe?
        Normally, it just reads info from all the EFI partitions to list the OS choices, but each bios is different in how it manages things.
        sudo fdisk -l will show details about both drives
          Here's the output of fdisk -l:
          Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
          Disk /dev/loop1: 63.45 MiB, 66531328 bytes, 129944 sectors
          Disk /dev/loop2: 63.46 MiB, 66547712 bytes, 129976 sectors
          Disk /dev/loop3: 73.9 MiB, 77492224 bytes, 151352 sectors
          Disk /dev/loop4: 236.85 MiB, 248352768 bytes, 485064 sectors
          Disk /dev/loop5: 236.91 MiB, 248418304 bytes, 485192 sectors
          Disk /dev/loop6: 346.33 MiB, 363151360 bytes, 709280 sectors
          Disk /dev/loop7: 349.7 MiB, 366682112 bytes, 716176 sectors
          Disk /dev/nvme0n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
          Disk model: Samsung SSD 970 EVO Plus 2TB
          Disklabel type: gpt
          Disk identifier: 130E7A97-AC5E-4DC4-A9D1-13F0E734167A
          Device Start End Sectors Size Type
          /dev/nvme0n1p1 2048 4095 2048 1M Linux filesystem
          /dev/nvme0n1p2 4096 1054719 1050624 513M EFI System
          /dev/nvme0n1p3 1054720 3907028991 3905974272 1.8T Linux filesystem
          Disk /dev/sda: 2.73 TiB, 3000588754432 bytes, 5860524911 sectors
          Disk model: ST3000DM001-1ER1
          Sector size (logical/physical): 512 bytes / 4096 bytes
          I/O size (minimum/optimal): 4096 bytes / 4096 bytes
          Disklabel type: gpt
          Disk identifier: 877D9D28-96A8-4D2E-B94B-38B7D3800FFA
          /dev/sda1 2048 194559 192512 94M EFI System
          /dev/sda2 194560 58796031 58601472 27.9G Linux filesystem
          /dev/sda3 5704273920 5860524031 156250112 74.5G Linux swap
          /dev/sda4 58796032 3130677091 3071881060 1.4T Linux filesystem
          /dev/sda5 3130677248 5704273919 2573596672 1.2T Linux filesystem
          Partition table entries are not in disk order.
          Disk /dev/sdb: 465.76 GiB, 500107862016 bytes, 976773168 sectors
          Disk model: WDC WD5000HHTZ-0
          Disklabel type: dos
          Disk identifier: 0x0001982e
          Device Boot Start End Sectors Size Id Type
          /dev/sdb1 2048 976771071 976769024 465.8G 83 Linux
          Disk /dev/loop8: 485.52 MiB, 509100032 bytes, 994336 sectors
          Disk /dev/loop9: 91.69 MiB, 96141312 bytes, 187776 sectors
          Disk /dev/loop10: 40.84 MiB, 42827776 bytes, 83648 sectors
          Disk /dev/loop11: 40.84 MiB, 42827776 bytes, 83648 sectors
          ​_________________________________________________ __
          When I look in QParted, /dev/nvme0n1p3 shows an EFI system partition. No other dev does.
            and
            I imagine you can nuke and pave over the the one you don't need, I am guessing sda1?
              I think it's sda5; that's the one showing the "extra" installation. /dev/nvme0n1p3 should have it. Do I need to redo the entire box, or can I just redo sda5? If the latter, will I need to modify/update grub?
                I think it's sda5
                No that is not an EFI partition, which is where bootloaders are kept.
                They are usually a few hundred Mb in size max, not Gb or Tb
                You can do whatever you want, but you don't need to 'redo' sda5, which seems to have an OS install on it, which is being pointed to from one of your BIOS boot options.
                But looking at your fstab again, your OS root is installed to /dev/sda2
                UUID=d6cc9de0-f209-45bb-b0b8-68a75ef42e3e / ext4 errors=remount-ro 0 1
                And your /home is on /dev/sda4
                UUID=f9cc9e42-b1df-4619-8287-de078eb92257 /home ext4 defaults 0 2​
                With the EFI (bootloader files for this OS install) being on the nvme drive.
                So the bootlaoder files are on the nvme, but the OS is on the sda drive, or rather the OS you were booted to when you copied your fstab is.
                So, I am a bit confused, not knowing what you have versus what you want. You have numerous partitions, so I don't want to muck something up.
                if you want the OS "/" and /home to be on the nvme, I think I's suggest starting over from scratch, in a sense.
                Since the SATA drive has your current /home, that can be used as a backup to restore your user configs and data files.
                I'd unplug the sata drive, reinstall Kubuntu, which will have all the partitions on the same drive. Then reconnect the sata drive, and copy the content of the /home/username on /dev/sda4 (after verifying that it is the correct one!) over to the new /home/username on the NVME. You can do this from a live session, or the installed OS.
                So, I can't really suggest what to really do here, and hoping others with less tired eyes can add useful stuff, or clarify what is muddy.
                  I took claydoh's advice, backed up /Home with all my data, and redid the machine. I'm back in business, with a single installation, /Home on a separate partition from the OS, and a separate backup drive for /Home. No data loss. Thanks to all.
