default sources.list?
    [RESOLVED] default sources.list?
    Hiya! My first time on these forums. I uh made an unfortunate mistake on Kubuntu 22.04... added a line to /etc/apt/sources.list in vim, forgot sudo, "remembered" the write with sudo trick, but did it wrong and clobbered the file. I typed `!sudo tee %` which i now realize overwrites an empty file. big oops. instead of the correct `w !sudo tee %`.
    I'm wondering if anyone would be so kind as to post the default /etc/apt/sources.list file? Would save me the hassle of installing Kubuntu 22.04 in a virtual machine to find standard content of this file.
    Many thanks!
    You can edit, or even replace a missing sources.list using the Software Sources tool, which can be found in Discover's settings area as well as in Muon's menus. or run from krunner ot the terminal via pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY software-properties-qt.
    Then, just check the options like so:
    If you had actually deleted the file, the Software Sources tool may not show up in Discover, if there are also no PPA or other sources present.
    The tool is still accessible from Muon or calling manually.
    But in any case here is the full default text from the file:
    #deb cdrom:[Kubuntu 22.04.2 LTS _Jammy Jellyfish_ - Release amd64 (20230223)]/ jammy main multiverse restricted universe
    # See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
    # newer versions of the distribution.
    deb http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
    # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
    ## Major bug fix updates produced after the final release of the
    ## distribution.
    deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
    # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
    ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
    ## team. Also, please note that software in universe WILL NOT receive any
    ## review or updates from the Ubuntu security team.
    deb http://us.archive.ubuntu.com/ubuntu/ jammy universe
    # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy universe
    deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
    # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
    ## team, and may not be under a free licence. Please satisfy yourself as to
    ## your rights to use the software. Also, please note that software in
    ## multiverse WILL NOT receive any review or updates from the Ubuntu
    ## security team.
    deb http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
    # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
    deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
    # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
    ## N.B. software from this repository may not have been tested as
    ## extensively as that contained in the main release, although it includes
    ## newer versions of some applications which may provide useful features.
    ## Also, please note that software in backports WILL NOT receive any review
    ## or updates from the Ubuntu security team.
    deb http://us.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
    # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
    deb http://security.ubuntu.com/ubuntu jammy-security main restricted
    # deb-src http://security.ubuntu.com/ubuntu jammy-security main restricted
    deb http://security.ubuntu.com/ubuntu jammy-security universe
    # deb-src http://security.ubuntu.com/ubuntu jammy-security universe
    deb http://security.ubuntu.com/ubuntu jammy-security multiverse
    # deb-src http://security.ubuntu.com/ubuntu jammy-security multiverse
    # This system was installed using small removable media
    # (e.g. netinst, live or single CD). The matching "deb cdrom"
    # entries were disabled at the end of the installation process.
    # For information about how to configure apt package sources,
    # see the sources.list(5) manual.
      This was such a lifesaver. Thank you! Checking options did not fix, but copying the default text did.
