Good morning,
For the last week I have been having trouble with the laptop keyboard not working properly. I did a fresh install during which all partitions except(!) /home were formatted. The problem has persisted. I am now thinking that there must be corruptions within files located in /home.
Yesterday, while I was trying to solve this, two things occurred. Firstly, a keyboard icon has now appeared in the system tray. Right-clicking on this and then selecting "Continue" from the pop-up menu that then appears causes a KDialog box to appear that displays the following text.
However when this dialog box's OK button is clicked, all that happens is that the dialog box disappears. Neither the default text editor nor the config file appear on screen. There is a Tux icon for Fcitx displayed in Program Launcher/System. When this is clicked nothing happens, meaning nothing appears on screen.
I should state that the login password can(!) be successfully entered using either the laptop keyboard or the external usb keyboard. Also, the external keyboard does respond normally after the system is first booted up but at some point thereafter it stops responding. This leaves the mouse as the only responding input device.
I also tried the fix discussed at
updates - Ubuntu 20.04 - keyboard not working - Ask Ubuntu
but this did not(!) work. Also, if the usb keyboard is disconnected very early in the reboot process, when the screen is black, and then reconnected after the desktop appears, the usb keyboard no longer responds.
I am at a loss as to what to try next.
Stuart
You're currently running KDE, but KCModule for fcitx couldn't be found, the package name of this KCModule is usually kcm-fcitx or kde-config-fcitx. Now it will open config file with default text editor.
Stuart
) doing just that. If/when that is completed, I will use the code you have provided to install the hwe kernel.
