System: Host: dh Kernel: 6.2.0-23-generic arch: x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM Distro: Ubuntu 23.04 (Lunar Lobster) Machine: Type: Desktop System: LENOVO product: 90BG003JUS v: Lenovo H50-55 serial: <superuser required> Mobo: LENOVO model: Bantry CRB v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO v: IRKT56AUS date: 01/19/2016 Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: 4055-46-3e-58-08 charge: 55% (should be ignored) rechargeable: yes status: discharging CPU: Info: quad core model: AMD A10-7800 Radeon R7 12 Compute Cores 4C+8G bits: 64 type: MT MCP smt: enabled arch: Steamroller rev: 1 cache: L1: 256 KiB L2: 4 MiB Speed (MHz): avg: 2120 high: 3095 min/max: 1400/3500 boost: enabled cores: 1: 3095 2: 2587 3: 1400 4: 1400 bogomips: 27945 Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: Micro-Star MSI driver: nvidia v: 530.41.03 arch: Maxwell pcie: speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1 empty: DVI-D-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:1380 class-ID: 0300 Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.8 compositor: kwin_x11 driver: X: loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 44 s-size: 1108x623mm (43.62x24.53") s-diag: 1271mm (50.04") Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: SP50M-C serial: 10SC330100001 res: 1920x1080 hz: 60 dpi: 45 size: 1095x616mm (43.11x24.25") diag: 1256mm (49.5") modes: max: 1920x1080 min: 640x480 API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2 direct-render: Yes Audio: Device-1: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403 Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403 Sound API: ALSA v: k6.2.0-23-generic running: yes Sound Server-1: PulseAudio v: 16.1 running: no Sound Server-2: PipeWire v: 0.3.65 running: yes Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200 IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: 00:01:6c:d3:dc:96 Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo driver: rtl8821ae v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:8821 class-ID: 0280 IF: wlp5s0 state: down mac: 68:14:01:24:67:c5 Bluetooth: Device-1: Realtek RTL8821A Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 4-2:2 chip-ID: 0bda:0821 class-ID: e001 serial: 00e04c000001 Report: hciconfig ID: hci0 rfk-id: 3 state: down bt-service: enabled,running rfk-block: hardware: no software: yes address: 68:14:01:24:67:C6 Drives: Local Storage: total: 1.38 TiB used: 101.91 GiB (7.2%) ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s type: SSD serial: S5B3NDFNA06046T rev: 4B6Q scheme: GPT ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s type: SSD serial: S3YANB0K951479K rev: 4B6Q scheme: GPT ID-3: /dev/sdc type: USB vendor: SanDisk model: Ultra size: 14.32 GiB type: N/A serial: 05014c14309045ea4a08da5c39ba4138de9cdd6d84360ee62cbe03b6d3ed0dd8f23700000000000000000000cd7591b4ff 1202108155810788a6a6cc rev: 1.00 scheme: MBR Partition: ID-1: / size: 456.89 GiB used: 74.53 GiB (16.3%) fs: ext4 dev: /dev/sdb2 ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sdb1 Swap: ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile Sensors: System Temperatures: cpu: 13.5 C mobo: N/A gpu: nvidia temp: 33 C Fan Speeds (RPM): N/A gpu: nvidia fan: 34% Repos: Packages: 2631 pm: dpkg pkgs: 2618 pm: snap pkgs: 13 Active apt repos in: /etc/apt/sources.list 1: deb http://us.archive.ubuntu.com/ubuntu/ lunar main restricted 2: deb http://us.archive.ubuntu.com/ubuntu/ lunar-updates main restricted 3: deb http://us.archive.ubuntu.com/ubuntu/ lunar universe 4: deb http://us.archive.ubuntu.com/ubuntu/ lunar-updates universe 5: deb http://us.archive.ubuntu.com/ubuntu/ lunar multiverse 6: deb http://us.archive.ubuntu.com/ubuntu/ lunar-updates multiverse 7: deb http://us.archive.ubuntu.com/ubuntu/ lunar-backports main restricted universe multiverse 8: deb http://security.ubuntu.com/ubuntu lunar-security main restricted 9: deb http://security.ubuntu.com/ubuntu lunar-security universe 10: deb http://security.ubuntu.com/ubuntu lunar-security multiverse No active apt repos in: /etc/apt/sources.list.d/neovim-ppa-ubuntu-stable-lunar.list Info: Processes: 248 Uptime: 1d 19h 6m wakeups: 48 Memory: 15.55 GiB used: 6.83 GiB (43.9%) Init: systemd v: 252 target: graphical (5) default: graphical Compilers: gcc: 12.2.0 alt: 12 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.25
Here you may see the issue. The LibreOffice menu is inserted into the top panel, separate from LO Calc. (A thin black line between them) Has anyone seen this behavior? It's a fresh(ish) install of 23.04. Next stoip is LibreOffice forum.
Any help is appreciated
