Can anyone tell me please how to do a clean install of Kubuntu 23.04. I want to clean my SSD and install a fresh copy. I have a so-called usb boot stick that isn't being used during a reboot (or power off/on). This used to work. I used Startup Disc Creator to make it. I also used dd with no change. The USB3 boot stick is plugged directly into a USB3 port but not found during boot.
Everything I see online about doing a fresh install I pretty much understand but it all comes back to the USB thumb drive not being recognised as a boot drive in a reboot. The "boot stick" is recognized as a drive however, as seen under drives below id 3 Cruzer Glide:
I listed all so you could see any problems.
Anyway, bit of a ramble but important to me as my system has become unwieldy and I want to start over. Can some help please?
Thank you very much!
I am linelocker
dave@dave:~$ inxi -Fxx System: Host: dave Kernel: 6.2.0-20-generic arch: x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 dm: 1: GDM3 2: SDDM Distro: Ubuntu 23.04 (Lunar Lobster) Machine: Type: Desktop System: LENOVO product: 90BG003JUS v: Lenovo H50-55 serial: <superuser required> Mobo: LENOVO model: Bantry CRB v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO v: IRKT56AUS date: 01/19/2016 Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: 4055-46-3e-58-08 charge: 55% (should be ignored) status: discharging CPU: Info: quad core model: AMD A10-7800 Radeon R7 12 Compute Cores 4C+8G bits: 64 type: MT MCP arch: Steamroller rev: 1 cache: L1: 256 KiB L2: 4 MiB Speed (MHz): avg: 1502 high: 1642 min/max: 1400/3500 boost: enabled cores: 1: 1397 2: 1400 3: 1572 4: 1642 bogomips: 27948 Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: Micro-Star MSI driver: nvidia v: 525.105.17 arch: Maxwell pcie: speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1 empty: DVI-D-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:1380 Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.8 compositor: kwin_x11 driver: X: loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1 Screen-1: 0 s-res: 1920x1080 s-dpi: 44 Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: SP50M-C res: 1920x1080 dpi: 45 diag: 1256mm (49.5") API: OpenGL v: 4.6.0 NVIDIA 525.105.17 renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2 direct-render: Yes Audio: Device-1: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc Sound API: ALSA v: k6.2.0-20-generic running: yes Sound Server-1: PulseAudio v: 16.1 running: no Sound Server-2: PipeWire v: 0.3.65 running: yes Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: 00:01:6c:d3:dc:96 Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo driver: rtl8821ae v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 10ec:8821 IF: wlp5s0 state: down mac: 68:14:01:24:67:c5 Bluetooth: Device-1: Realtek RTL8821A Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 4-2:2 chip-ID: 0bda:0821 Report: hciconfig ID: hci0 rfk-id: 1 state: up address: 68:14:01:24:67:C6 bt-v: 2.1 lmp-v: 4.0 sub-v: a041 Drives: Local Storage: total: 1.39 TiB used: 288.18 GiB (20.2%) ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s serial: S5B3NDFNA06046T ID-2: /dev/sdb vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB speed: 6.0 Gb/s serial: S3YANB0K951479K ID-3: /dev/sdc type: USB vendor: SanDisk model: Cruzer Glide 3.0 size: 28.65 GiB
I am linelocker
