Today's kernel update loaded multiple kernel versions, none of which work
    I posted about this right after it happened (couple days ago, now), and the entire thread is gone; even using the link that came in a reply notification email takes me to a "not found" page. On the presumption that if I'd been moderated I'd have gotten some kind of message, I presume the board glitched and lost the thread, so I'll ask again.
    I got an update that included a kernel upgrade from 5.15.0-67-generic to 5.15.0-69-generic, but also installed four additional kernels: 5.15.0-1018-nvidia, 5.15.0-1032-oracle, 5.17.0-1029-oem, 6.0.0-1013-oem, and 6.1.0-1008-oem. Of these, NONE will boot with full success. All but 5.15.0-1018-nvidia will lock up early in the process (around 15-16 seconds is the last time tag I see, shortly after the USB3 port errors have listed), and that one starts to desktop, but without finding either network (on-motherboard gigabit ethernet that's worked correctly since I installed this motherboard in December) or sound hardware (six-pack on-motherboard, working correctly since motherboard installation).
    Rebooting to 5.15.0-67-generic fixed it, but I'm curious why this happened and how I can either (preferred) get rid of the extra kernels so they don't just reinstall when the updater notices I don't have them, but without disabling kernel updates for when 5.15.0-69-generic is replaced with one that works; OR at the least, how I can get GRUB to default to boot in 5.15.0-67-generic and keep this kernel from being deleted by upgrades until I have one or two newer working kernels in /boot.
    Odd, will look into it.
    In the meantime:
    https://www.kubuntuforums.net/forum/...nels-installed
    and
    https://www.kubuntuforums.net/forum/...en-won-t-start
    Grub-customizer can set defualt boot kernels.
      I am not terribly good with the backend stuff with the software, and I can't see what happened to the thread, Apologies.
      Def not moderated. We don't actually do that very often. It well could be that I did something accidentally, or triggered a bug in the software, but I can't see any record of the thread that I clearly remember, and iirc commented on.
      No idea what this happened. The kernels are not part of any meta-package that would pull them in at all, and are rather specialized.
      They probably didn't work as they are either missing support some some things by design since they are meant for servers or cloud instances (-oracle and -nvidia), and/or DKMS failed to build the modules for some reason (Nvidia drivers, for example)
      Normally, these would need to be installed manually, and would not be included an any dependency list on their own.
      You can use Muon to search for linux-image and linux-headers, and filter for installed packages. Then select anything with -oem, -nvidia, and -oracle, and uninstall them.
      No clue why this has happened, so I can't say they won't be pulled in again, since we don't know what you have installed that is depending on these. But I think it is unlikely. Uninstalling these kernels will also want to remove whatever needs these, perhaps, so it might be useful to post the list of everything that is slated for removal, as well as maybe offered for autoremove afterward.
      This sort of thing is not related to Plasma or Kubuntu, since the desktop GUI doesn't depend on kernels and I am not seeing reports of this happening in the Ubuntu and Kubuntu places I haunt, so far.
      I suspect some odd piece of software or package from a third party, like a PPA. It would be happening *everywhere* if it was a general packaging configuration bug in a standard *buntu package.
      And I don't see three people here at the same time having manually installed the same oddball kernels.
        Okay, thanks for the help. I've installed grub-customizer, now to remove those kernels.
        I'm used to using Synaptic, so I'm using it trying to uninstall those packages, but it wants to reinstall linux-image-5.15.0-69-generic as part of "complete removal" (= purge) of that package along with some others; it's also wanting to install linux-image-unsigned-5.15.0-1018-nvidia along with upgrading a bunch of what look like driver related packages (which I presume would be fine) when I try to remove the installed (without "unsigned") version. The same applies for linux-image-6.1.0-1008-oem. I'm going to dump the others now (success for those not listed above).
        Probably significant: here's a fragment of what I get when I used sudo apt purge linux-image-5.15.0-69-generic:
        The following additional packages will be installed:
         linux-image-unsigned-5.15.0-69-generic
        Suggested packages:
         fdutils linux-doc | linux-source-5.15.0 linux-tools linux-modules-extra-5.15.0-69-generic
         linux-generic* linux-image-5.15.0-69-generic* linux-image-generic* linux-modules-extra-5.15.0-69-generic*
        Note that it would remove the linux-generic* metapackage. This must be why it needs a reinstall of at least some version of those packages that won't go away.
        Just to make sure I don't have something else that might confuse things, I'm pasting in my repository list:
        # deb cdrom:[Kubuntu 22.04.1 LTS _Jammy Jellyfish_ - Release amd64 (20220809.1)]/ jammy main multiverse restricted universe
        # See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
        # newer versions of the distribution.
        deb http://us.archive.ubuntu.com/ubuntu/ jammy restricted main
        # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
        ## Major bug fix updates produced after the final release of the
        ## distribution.
        deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates restricted main
        # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
        ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
        ## team. Also, please note that software in universe WILL NOT receive any
        ## review or updates from the Ubuntu security team.
        deb http://us.archive.ubuntu.com/ubuntu/ jammy universe
        # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy universe
        deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
        # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
        ## team, and may not be under a free licence. Please satisfy yourself as to
        ## your rights to use the software. Also, please note that software in
        ## multiverse WILL NOT receive any review or updates from the Ubuntu
        ## security team.
        deb http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
        # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
        deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
        # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
        ## N.B. software from this repository may not have been tested as
        ## extensively as that contained in the main release, although it includes
        ## newer versions of some applications which may provide useful features.
        ## Also, please note that software in backports WILL NOT receive any review
        ## or updates from the Ubuntu security team.
        deb http://us.archive.ubuntu.com/ubuntu/ jammy-backports universe restricted main
        # deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
        deb http://security.ubuntu.com/ubuntu/ jammy-security restricted main
        # deb-src http://security.ubuntu.com/ubuntu/ jammy-security main restricted
        deb http://security.ubuntu.com/ubuntu/ jammy-security universe
        # deb-src http://security.ubuntu.com/ubuntu/ jammy-security universe
        # deb http://security.ubuntu.com/ubuntu/ jammy-security
        # deb-src http://security.ubuntu.com/ubuntu/ jammy-security multiverse
        # This system was installed using small removable media
        # (e.g. netinst, live or single CD). The matching "deb cdrom"
        # entries were disabled at the end of the installation process.
        # For information about how to configure apt package sources,
        # see the sources.list(5) manual.
        deb http://downloads.sourceforge.net/project/ubuntuzilla/mozilla/apt/ all main
        I also have the following PPA folders in sources.list.d.
        $ ls
        alexlarsson-ubuntu-flatpak-jammy.list  teejee2008-ubuntu-ppa-jammy.list
        megasync.list                          trebelnik-stefina-ubuntu-grub-customizer-jammy.list
        The only thing I'm aware of that amounts to "pushing" my install is llvm which is needed to have math libraries for a Kerbal Space Program mod that I'm pretty sure at least hundreds of Kubuntu users run. I can post a package list if that will help, but it's biggish...
          Thinking about what I might have installed that could have pulled this (though at least one of the bad kernels was apparently pulled by linux-generic metapackage) -- I run GIMP from Snap, Kerbal Space Program manually installed, Vuescan 64 manually installed, GURPS Character Sheet manually installed. The PPA entries above are for Megasync (remote archive downloader I got for itch.io distributed indy games), grub-customizer, and flatpak, which ought not to pull anything as dependencies (and doesn't show any dependencies anyway).
          Everything else installed is from main, backports, multiverse, universe, or restricted.
          Could this be coming from something installed via backports (Libre Office)? Those are packages from newer Ubuntu versions, ported to work on this LTS, right?
            if the linux-generic metapackage​ pulled these in, it would have affected *everyone*, or at least a very significant portion of those running *buntu and unofficial variants.
            Unless it was a mistake that was caught so fast that only a small few were caught but it (pure conjecture here. There are interconnecting and overlapping meta-packages, virtual packages, and all sorts of other goodies involved in Debian packaging).
            Even PPAs would be a low-chance cause, I think.
            The versions of the packages installed don't seem to be from jammy-backports. Still, this would have affected most people.
            An example:
            apt policy linux-image-5.15.0-69-generic
            Installed: 5.15.0-69.76
            Candidate: 5.15.0-69.76
            Version table:
            *** 5.15.0-69.76 500
            500 http://security.ubuntu.com/ubuntu jammy-security/main amd64 Packages
            500 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
            100 /var/lib/dpkg/status
            ​Now, these could have previously been in jammy-proposed, but that definitely takes manual intervention to enable (and it isn't seen in your sources.list)
            Now, as to your PPAs, what is this one from, exactly?
            If it is from HERE, it would not have any Jammy packages to begin with - it is old, no packages past 20.04. You should be seeing errors/warnings about it in apt.
            You can safely delete that file. This has no effect on these odd kernels, though.
              Also, your sources.list need fixing:
              # deb http://security.ubuntu.com/ubuntu/ jammy-security  <-----------------------------THIS
              # deb-src http://security.ubuntu.com/ubuntu/ jammy-security multivers​e
              should be:
              deb http://security.ubuntu.com/ubuntu/ jammy-security multiverse
              It needs to be un-commented, and have 'multiverse' at the end.
              This also isn't any reason for the odd kernel installs. But it is good to have all security updates available
                I don't recall where the alexlarsson-ubuntu-flatpak-jammy.list came from, but probably got upgraded from 20.04 to 22.04 during my failed upgrade attempt and install-over to fix my system, over Christmas break. Obviously, I had it there to be able to install a flatpak, but I don't recall which -- maybe I had a flatpak version of SeaMonkey browser on 20.04, but got it from multiverse after my upgrade was completed. As you note, Synaptic doesn't show any packages installed from it.
                I've removed it, and updated the jammy-security line as you recommend. After doing so, ran sudo apt update and sudo apt dist-upgrade, got no changes but once again saw the "advertising" recommendations for the Ubuntu Pro security extensions....
                I get the same you do on policy:
                sudo apt policy linux-image-5.15.0-69-generic
                Version table:
                500 http://us.archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages
                But then:
                $ sudo apt policy linux-image-5.15.0-1018-nvidia
                linux-image-5.15.0-1018-nvidia:
                Installed: 5.15.0-1018.18
                Candidate: 5.15.0-1018.18
                Version table:
                *** 5.15.0-1018.18 500
                and:
                $ sudo apt policy linux-image-6.1.0-1008-oem
                linux-image-6.1.0-1008-oem:
                Installed: 6.1.0-1008.8
                Candidate: 6.1.0-1008.8
                Version table:
                *** 6.1.0-1008.8 500
                These are the three I can't remove without Synaptic (presumably to fulfill some dependency) wanting to install an alternative version.
                Unless it was a mistake that was caught so fast that only a small few were caught but it (pure conjecture here. There are interconnecting and overlapping meta-packages, virtual packages, and all sorts of other goodies involved in Debian packaging).​
                If that were the case, would reinstalling linux-generic fix the dependencies and let me at least remove the stuck -nvidia and -oem packages? Or would that have other unwanted effects?
                $ sudo apt reinstall linux-generic*
                Reading package lists... Done
                Building dependency tree... Done
                Note, selecting 'linux-generic-hwe-20.04' for glob 'linux-generic*'
                Note, selecting 'linux-generic' for glob 'linux-generic*'
                Note, selecting 'linux-generic-hwe-22.04' for glob 'linux-generic*'
                Note, selecting 'linux-generic-hwe-20.04-edge' for glob 'linux-generic*'
                Note, selecting 'linux-generic-hwe-22.04-edge' for glob 'linux-generic*'
                linux-headers-5.19.0-38-generic linux-headers-generic-hwe-22.04
                linux-headers-generic-hwe-22.04-edge linux-hwe-5.19-headers-5.19.0-38
                linux-image-5.19.0-38-generic linux-image-generic-hwe-22.04
                linux-image-generic-hwe-22.04-edge linux-modules-5.19.0-38-generic
                linux-modules-extra-5.19.0-38-generic
                Suggested packages:
                fdutils linux-doc | linux-hwe-5.19-source-5.19.0 linux-hwe-5.19-tools
                linux-generic-hwe-20.04 linux-generic-hwe-20.04-edge linux-generic-hwe-22.04
                linux-generic-hwe-22.04-edge linux-headers-5.19.0-38-generic
                linux-headers-generic-hwe-22.04 linux-headers-generic-hwe-22.04-edge
                linux-hwe-5.19-headers-5.19.0-38 linux-image-5.19.0-38-generic
                linux-image-generic-hwe-22.04 linux-image-generic-hwe-22.04-edge
                linux-modules-5.19.0-38-generic linux-modules-extra-5.19.0-38-generic
                0 upgraded, 13 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                Need to get 124 MB/124 MB of archives.
                After this operation, 739 MB of additional disk space will be used.
                  The only packages in that PPA for Focal Fossa are/were:
                  First • Previous • Next • Last
                  flatpak 1.12.4-1flatpak1~20.04 Simon McVittie (2022-01-20)
                  flatpak-builder 1.2.2-2flatpak1~20.04 Simon McVittie (2022-01-20)
                  ostree 2020.8-flatpak1~focal Alexander Larsson (2020-11-19)
                  xdg-desktop-portal 1.8.1-1~flatpak1~20.04 Simon McVittie (2022-01-13)
                  xdg-desktop-portal-gtk 1.8.0-1~flatpak1~20.04 Simon McVittie (2022-01-13)
                    Then it is disabled, anyway. The upgrade process does that to PPAs, so it isn't actually being used, which explains a lack of messages (doh!)
                    That may be a clue - a virtual package that needs one of a list of items to satisfy.
                    I admit these are weird and I don't understand well. I barely understand some of the basics.
                    A virtual package is satisfied with any one of a number of packages that are designated to "Provide" it. One would be installed, not all of them, though.
                    I think.
                    Maybe.
                    I think have a headache now lol!
                    Actually, it might.
                    But: Hmmmm:
                    <--- I spy an extra bit here
                    Using the wildcard option ( the * ) in a command will Install all packages with that text in the name.
                    Try it without the star. Actually, linux-generic-hwe-22.04​ is the appropriate kernel metapackage for the 5.19 kernel that most people on 22.04 are running. It shouldn't make things worse.
                    (the * at the end of some package names WILL be seen in the output when using apt purge. This designates which packages are having system config files removed, etc. In most other places, the star is just a simple regex to "match everything")
                      Okay, I'll try reinstalling linux-generic-hwe-22.04 (will need a restart, so I'll have to come back and post results). I've run HWE kernel series on 16.04 and 20.04, don't remember why I started doing so, I certainly don't have any cutting-edge hardware (obsolete motherboard, FX8350 CPU, GTx 1070 GPU).
                      Okay, installed that meta-package(sudo apt install linux-generic-hwe-22.04), nothing was removed (installed 8 packages, all for the 5.19.0-38 HWE stack). Ran sudo update-grub, then used Configure GRUB (from GUI) to check that hadn't added back the non-working kernels. Rebooted into 5.19.0-38 -- and got a lockup on console screen after a short period with Kubuntu logo and "press any key to stop disk checks in progress." No login prompt, even with Alt-F1 (or Ctl-Alt-F1, never can remember which I want and tried both). So I'm back to 5.15.0-67, and attempting to purge 5.15.0-69 still results in apt trying to install the *-unsigned-* version.
                        Sigh...
                        Got another routine update today. That installed kernel 5.15.0-70-generic, as one might expect, as well as 5.19.0-40-generic (which I presume is the HWE path).
                        Neither one will boot. Where can I find the logs that will help nail down what's going on here? Getting one bad upgrade I can understand; that's most of why the updater keeps some old kernel versions -- but getting two in a row that won't boot?
                          Sounds like you might be missing some needed packages. Are you using a DKMS driver like nVidia?
                          Run dkms status and if you get nothing then your not using dkms. If you do get output, make sure all the kernels have whatever dkms module is built.
                          If dkms isn't the issue, look at whats installed to verify all needed extra packages are there. For example, I'm using 5-15.0-69-generic kernel Entering this:
                          dpkg -l |grep 5.15.0-69 | awk '{print $2}'
                          returns this output
                          linux-headers-5.15.0-69
                          linux-headers-5.15.0-69-generic
                          linux-modules-5.15.0-69-generic
                          Run the above dpkg statement on the working and then on the non-working kernels to see if all the packages were installed.
                            I had to install
                            dkms
                            but once that was done I got no output from it (currently running 5.15.0-67-generic, as it's the latest that will boot to GUI). I do have nVidia driver 515 metapackage, and my display performance seems normal (very similar to what I had in 20.04 a few months ago); also, I have the nVidia X control panel showing, though it's less detailed than it used to be (that may be an nVidia change).
                            For the one that works (5.15.0-67-generic):
                            $ dpkg -l | grep 5.15.0-67 | awk '{print $2}'
                            linux-headers-5.15.0-67
                            linux-headers-5.15.0-67-generic
                            linux-image-5.15.0-67-generic
                            linux-modules-5.15.0-67-generic
                            linux-modules-extra-5.15.0-67-generic
                            linux-modules-nvidia-515-5.15.0-67-generic
                            linux-objects-nvidia-515-5.15.0-67-generic
                            linux-signatures-nvidia-5.15.0-67-generic
                            For the newest HWE kernel installed today:
                            $ dpkg -l | grep 5.19.0-40 | awk '{print $2}'
                            linux-headers-5.19.0-40-generic
                            linux-hwe-5.19-headers-5.19.0-40
                            linux-image-5.19.0-40-generic
                            linux-modules-5.19.0-40-generic
                            linux-modules-extra-5.19.0-40-generic
                            ​For the newest non-HWE, also installed today, that also won't boot:
                            $ dpkg -l | grep 5.15.0-70 | awk '{print $2}'
                            linux-headers-5.15.0-70
                            linux-headers-5.15.0-70-generic
                            linux-image-5.15.0-70-generic
                            linux-libc-dev:amd64
                            linux-modules-5.15.0-70-generic
                            linux-modules-extra-5.15.0-70-generic
                            Apparently, the nVidia blob isn't getting into these newer kernels (why? Dunno). If I change the nVidia version I'm using via Driver Manager, I believe that will install itself in every kernel it finds, correct? I have nVidia 530 listed as (proprietary, tested) in Driver Manager, I could upgrade to that.
                              Do that - best in Konsole with
                              ubuntu-drivers devices to list the available drivers and
                              sudo ubuntu-drivers autoinstall OR sudo ubuntu-drivers install nvidia:530 to install it,
                              so you can see what is happening (e.g. for which kernels the additional Nvidia stuff is installed).
                              See: https://help.ubuntu.com/community/Nv...rsInstallation
