Originally posted by Michel Frey
View Post
If there already is an EFI partition you can skip step 5A, if not create one that is at least 300MB in size, not just 256MB (I mostly use 304 or 320MB - reason, without being an actual technical reason: some other Linux distributions than *Ubuntu - actually their installer - demand an EFI partition size of at least/greater than 300MB, so you will be on the safe side for the future).
You can skip step 5B as Kubuntu will automatically create a swap file in your / directory - sufficient for your use case I presume.
If you want to place your mount points manually (that is what the whole step 5 is about) point /boot/efi to the EFI partition in step 5D. If is already there don't erase it, just point to it - otherwise your Windows boot loader will be gone!
I hope this helps.
