Discover Filled Up /usr
    I can't do any more updates because my /usr partition is now full. I'd love to resize its virtual disk in VirtualBox but can't figure out how to do that, either.
    Unless you created a specific partition for /usr, which is not a common thing to do, it is all part of your / (root) partition.
    How big a virtual drive do you have? What is your partition layout, if you did a custom install layout?
    You probably just need to uninstall some software, for starters.
    There are command line tools to help do some cleanup as well
    https://www.omgubuntu.co.uk/2016/08/...pace-on-ubuntu
    I recommend skipping step 4, the wrong settings in that app can be a bit too aggressive, and remove too many important things.
    As to enlarging a virtual drive, it requires two major steps, basically
    https://www.howtogeek.com/124622/how...box-or-vmware/
    In the above, you can use the Kubuntu installer ISO instead of GParted, and run Partition Manager from that to grow the partition to fit the new disk size.
    • oshunluvr
      oshunluvr commented
      Editing a comment
      Wow, you really do "bing" it for everyone...
    • claydoh
      claydoh commented
      Editing a comment
      oshunluvr I know-ish what to do, but being a lazy sod who types pooorly, I find and vette some better, reasonably up to date instructions, rather than type it all out and create all the screenshots.
      I haven't used Virtualbox in ages, so that adds even more work.
