No Input soud device detected in Kubuntu 22.04 LTS
    [SOLVED] No Input soud device detected in Kubuntu 22.04 LTS
    Hello, I installed Kubuntu 22.04 LTS on my Chromebook by installing SeasBios on it and the sound is working but the microphone isn't.
    Have someone an idea on how correct this ?
    Thanks.
    It may be difficult, or might simply not be supported. Chromebooks are not like normal PCs, with most everything is in the chip, as opposed to separate components. Many Chromebooks simply don't have any sound support, period, mainly due to Intel not providing the firmware driver blobs or proper specs and sources
    This highly depends on the specific system board used, so some model numbers and hardware info would be helpful. (hint hint )
    You might use alsamixer in the terminal and see if it hasn't been simply disabled.
    fwiw, this problem will be a general Linux one, not specific to Kubuntu.
      You might try what I had to do a few days ago: lenovo thinkpad internal microphone disappeared
        Thanks for your responses.
        When I launch the command "pacmd list-cards" it say that I've 1 card :
        pacmd list-cards
        1 card(s) available.
           index: 0
               driver: <module-alsa-card.c>
               owner module: 7
               properties:
                       alsa.card = "0"
                       alsa.card_name = "sof-glkda7219max"
                       alsa.long_card_name = "Google-Droid-rev4"
                       alsa.driver_name = "snd_soc_sst_bxt_da7219_max98357a"
                       device.bus_path = "pci-0000:00:0e.0-platform-glk_da7219_mx98357a"
                       sysfs.path = "/devices/pci0000:00/0000:00:0e.0/glk_da7219_mx98357a/sound/card0"
                       device.bus = "pci"
                       device.vendor.id = "8086"
                       device.vendor.name = "Intel Corporation"
                       device.product.id = "3198"
                       device.product.name = "Celeron/Pentium Silver Processor High Definition Audio"
                       device.string = "0"
                       device.description = "Celeron/Pentium Silver Processor High Definition Audio"
                       module-udev-detect.discovered = "1"
                       device.icon_name = "audio-card-pci"
               profiles:
                       output:stereo-fallback: Sortie Stéréo (priority 5100, available: unknown)
                       off: Éteint (priority 0, available: unknown)
               active profile: <output:stereo-fallback>
               sinks:
                       alsa_output.pci-0000_00_0e.0-platform-glk_da7219_mx98357a.stereo-fallback/#0: Celeron/Pentium
        Silver Processor High Definition Audio Stéréo
               sources:
                       alsa_output.pci-0000_00_0e.0-platform-glk_da7219_mx98357a.stereo-fallback.monitor/#0: Monitor
        of Celeron/Pentium Silver Processor High Definition Audio Stéréo
               ports:
                       analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: unknown
                               properties:
                                       device.icon_name = "audio-headphones"[COLOR=#000000][/COLOR]
        And when I launch pavucontrol, in input devices, it say "Monitor of Celeron/Pentium Silver Processor High Definition Audio Stéréo".
          I've an Acer Chromebook 314 (Droid) on which I installed SeasBIOS with MrChromebox script.
          It has an Intel Celeron N4020 CPU @1.10GHz.
            Looking at info for various Gemini Lake Chromebooks, there seems to be some potential workarounds for the sof-glkda7219max audio issues.
            here are some potentially useful links that are good starting points for research
            https://www.reddit.com/r/chrultraboo...fglkda7219max/
            https://bbs.archlinux.org/viewtopic.php?id=276860
            Also, I forgot this interesting project i started looking at, but ended up selling my x86 Chromebook to purchase my arm64 Lenovo Duet 5
            https://www.omgubuntu.co.uk/2022/07/...romebook-cp713
            Since you already have Kubuntu installed, the info in the first two links are where I'd start. it seems that it just needs custom/correct UCM files and some various configuration mods.
              Thank a lot for your response ! I've launched this script : https://gist.githubusercontent.com/u.../gistfile1.txt, rebooted my computer and now 2 input devices appears and when I come in Discord for example and I come in a voice channel, it's working !
              How can I mark this topic as resolved ? (I've forgotten to say I am French so excuse me if my English isn't great)
              Thanks again to everyone helped me !
                Glad it worked!
                I need to get back in to x86 Chromebooks, I did enjoy tinkering on them. it is good to hear that there is finally better audio support on more recent models!
                Go to your first post, and edit it. You can add a prefix for [SOLVED].
