Hi folks
First time poster here. I hope someone more knowledgeable then me in computer matters might clarify this situation.
Just installed Kubuntu20.04 22.04 on my old computer with 2 gigs of RAM and 500 gigs of hard drive.
The system installed just fine, with Kubuntu taking over entire hard drive. After installation and some period of usage (sometimes it's few minutes, sometimes an hour or two), the desktop would freeze.
Upon hard reset it would come to this:
Loading Linux 5.15.0-41-generic ...
error: attempt to read or write outside of disk 'hd0'.
Loading initial ramdisk ...
error: you need to load the kernel first.
Press any key to continue..._
then this:
*Ubuntu
Advanced options for Ubuntu
Memory test (memtest86+.elf)
Memory test (memtest86+bin, serial console)
and then full screen of gibberish (to me), and the last 2 lines:
[ 1.335084] Kernel Offset: 0x9800000 from 0xfffffff81000000 (relocation range: 0xfffff800000000-0xfffffffbfffffff)
[1.3350840] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
If I shut down computer for few minutes, then the system starts up just fine.
My uneducated guess would be a failing hard drive.
The reason why I installed Kubuntu is because I had an older Linux Mint installed, which was no longer supported and started just shutting down without warning on me.
Do I need to get a new hard drive? Or is it just something software related?
Thank you for any insight.
then this:
*Ubuntu
