"safely remove" SD card immediately re-mounted
    Hello,
    Having just installed Jammy, my main annoyance is that the UI to "safely remove" (i.e. unmount) a removable storage device doesn't really work. It does the unmount but the device is immediately re-mounted again. Here's the entries from syslog.
    Jun 13 12:30:27 orion kernel: [343234.328540] audit: type=1400 audit(1655116227.430:7021): apparmor="DENIED" operation="open" profile="snap.firefox.firefox" name="/etc/fstab" pid=531159 comm="firefox" requested_mask="r" denied_mask="r"
    fsuid=1026 ouid=0
    Jun 13 12:30:27 orion kernel: [343234.334081] audit: type=1400 audit(1655116227.438:7022): apparmor="DENIED" operation="open" profile="snap.firefox.firefox" name="/run/mount/utab" pid=531159 comm="firefox" requested_mask="r" denied_mask
    ="r" fsuid=1026 ouid=0
    Jun 13 12:30:23 orion rtkit-daemon[1529]: Supervising 1 threads of 1 processes of 1 users.
    Jun 13 12:30:27 orion udisksd[912]: Cleaning up mount point /media/jon/3563-6562 (device 179:1 is not mounted)
    Jun 13 12:30:27 orion systemd[1]: media-jon-3563\x2d6562.mount: Deactivated successfully.
    Jun 13 12:30:27 orion udisksd[912]: Unmounted /dev/mmcblk0p1 on behalf of uid 1026
    Jun 13 12:30:27 orion kernel: [343234.405014] mmcblk0: p1
    Jun 13 12:30:27 orion systemd-udevd[663001]: mmcblk0p1: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/mmcblk0p1' failed with exit code 1.
    Jun 13 12:30:27 orion udisksd[912]: Mounted /dev/mmcblk0p1 at /media/jon/3563-6562 on behalf of uid 1026
    Jun 13 12:30:27 orion kernel: [343234.588265] audit: type=1400 audit(1655116227.690:7023): apparmor="DENIED" operation="open" profile="snap.firefox.firefox" name="/etc/fstab" pid=531159 comm="firefox" requested_mask="r" denied_mask="r"
    fsuid=1026 ouid=0
    Jun 13 12:30:27 orion kernel: [343234.592793] audit: type=1400 audit(1655116227.694:7024): apparmor="DENIED" operation="open" profile="snap.firefox.firefox" name="/run/mount/utab" pid=531159 comm="firefox" requested_mask="r" denied_mask
    I have to unmount the SD card manually - which fortunately doesn't automatically re-mount.
    Has anyone seen anything like this?
    Thanks in advance
    Jon
    Haven't had my morning quota of coffee yet, but from what you've posted from syslog, it "appears" that Firefox is involved in the SD getting remounted? Why would that be? Hmm.
      I think this is a symptom, not a cause, it *may* be related to a bug on systemd /udev services.
      https://bugs.launchpad.net/ubuntu/+s...x/+bug/1971955
      https://bugs.launchpad.net/ubuntu/+s...d/+bug/1966203
      Some service or udev rule may be causing it to call the unshare/snapd command
