Updated to 22.04 from 21.10. Seemed to go well except for the following error at the end. The package refuses to uninstall and gets the following error:
The system boots and seems to operate as expected, except that the package manager indicates that updates are available when there are none.
Any ideas how to fix this?
Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be REMOVED: linux-image-5.13.0-28-generic 0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade. 1 not fully installed or removed. After this operation, 10.3 MB disk space will be freed. Do you want to continue? [Y/n] (Reading database ... 283445 files and directories currently installed.) Removing linux-image-5.13.0-28-generic (5.13.0-28.31) ... /etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting /boot/initrd.img-5.13.0-28-generic /etc/kernel/postrm.d/zz-update-grub: Sourcing file `/etc/default/grub' Sourcing file `/etc/default/grub.d/init-select.cfg' Generating grub configuration file ... /etc/grub.d/bin/grubcfg_proxy: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory run-parts: /etc/kernel/postrm.d/zz-update-grub exited with return code 127 dpkg: error processing package linux-image-5.13.0-28-generic (--remove): installed linux-image-5.13.0-28-generic package post-removal script subprocess returned error exit status 1 dpkg: too many errors, stopping Errors were encountered while processing: linux-image-5.13.0-28-generic Processing was halted because there were too many errors. E: Sub-process /usr/bin/dpkg returned an error code (1)
