Custom Device Action to power of a removable device that is not mounted
    Currently there seems to be no option in the GUI to power off a removable device which is not mouted (safely remove).
    The command line option i found in a forum is:
    1. look up device name manually
      udisksctl status
    2. power off device
      udisksctl power-off -b /dev/sdX​
    I would like to simplify this process by adding a custom "Device Action" which does this for the selected device.
    I tried to do this but several problems appeared which I am unable to solve.
    First of all I was able to create a custom action.
    But I didn't know what the paramters (%f, %d, %i) stood for exactly so I tried to write a debug command:
    echo "test %f %d %i" &> ~/debug_custom_action.log
    This left me with an empty file so I tried to simplify it:
    echo "test" &> ~/debug_custom_action.log
    This command still leaves me with an empty file if I run it as a device action. If I run it from the Konsole instead it works as expected.
    Could anybody please help me figure this out?
    References:
